Boost Leak Test
So where does the air your pumping into the turbo actually stop at then i assume it fills the inlet manifold which in turn would then go into the head and past any inlet valves that are open. I could be well off here but does it not reach the pistons in the end?
You got it right. Wheather the valves are open or closed will determine if the air gets to the cylinders. If open then air will reach and if closed it wont. For a compression test though you should be in the 160ish psi region on a cold engine. My TSi was 165psi on a cold engine across the board. So a boost leak test wont generate anywhere near enough pressure for a compression test.
[WTB] Evo 8 Throttle Body.
4b11slayer
Dec 31, 2016 01:16 PM
evilrevo8
10
May 17, 2009 03:09 AM
