23 psi on untuned EVO IX ok?
Old Jul 10, 2008 | 03:58 PM
purekoryo's Avatar
Currently have EVO IX with just k&n filter and TBE. I would like to do a mail-in tune, but that requires several runs in 3rd gear at whatever psi I want to tune at; however, will 23 psi untuned put me in the danger zone for the engine detonating? or will it retard the timing so that the tuner won't be able to see the true numbers? Is the stock fuel pump ok for 23 psi?
Old Jul 10, 2008 | 04:07 PM
kreionic's Avatar
you should be fine. the car runs so rich from the get go. Yes the boost will lean you out a little but i wouldnt worry. I am surprised your tuner isnt going to start off and then work his way up. Especially since its through email i would think he would do gradual steps or atleast a timing and a/f thats super safe for your boost and then work timing, mivec and a/f up
Old Jul 10, 2008 | 04:36 PM
kaonashi's Avatar
mine did fine on 24 psi on 93 octane.
Old Jul 10, 2008 | 05:01 PM
wshihdnevo's Avatar
You should be more than fine.
Old Jul 10, 2008 | 05:56 PM
purekoryo's Avatar
24 psi untuned?
I will also get mine mellon tuned. What was your procedure in detail with him in getting your car tuned via mail-in?
thanks
Old Jul 10, 2008 | 06:13 PM
kaonashi's Avatar
I got mine tuned over the net, I did the pulls and he adjusted accordingly. I'm still not 100% tuned yet my wideband started messing up so it halted the processes. but he's great to work with, excellent tuner also.
Old Jul 10, 2008 | 07:00 PM
IXmr321's Avatar
Who are you sending it to for the tune?
To be on the safe side, I'd throw in a walbro 255.
Old Jul 11, 2008 | 11:58 AM
Mellon Racing's Avatar
thanks Mick, looking forward to picking things back up with yours
thanks
check out www.mellontuning.com it covers most everything you need to know and even has links to the equipment you'll need to get started
Old Jul 11, 2008 | 12:39 PM
wshihdnevo's Avatar
A walbro really isnt neccessary unless you are around the 350+ mark. The IX pump flows pretty well...
Old Jul 11, 2008 | 01:16 PM
there's plenty of EVO 8 guys doing tbe, 23psi via mbc and exhaust on the stock pump. The walbro 255 is about 90 bucks and necessary beyond that when you start doing fmic, cams, porting, turbo
sp00lin9
10
Feb 27, 2016 03:09 PM
Evo MR IX Fritz
Aug 22, 2012 01:21 PM
jsan1020
Jul 2, 2011 07:27 PM
F0RSAKEN
Nov 30, 2009 04:30 PM
