Walbro 255 and fuel filter
The part on the bottom of the pump is not a "filter", it is referred to as a sock. Yes, it has some filtering capability but is not the actual filter. The filter on the EVO is built into the fuel pump assembly and cannot be replaced, the entire fuel pump assembly has to be replaced to change the filter. I am referring to the entire big white part in the tank the fuel pump is in.
Where is the filter in the assembly? Or are you talking about the small little filter on the other side of the saddle?
He is saying that the filter is actually inside the play that this diagram has circled as "fuel pump or fuel module." That whole unit is white in color and plastic.. He is saying you would have to get an entire assembly (white plastic) to replace the actual filter.. It is supposedly inside of the unit itself..
That's what I thought too... but Dave's post was implying that it is inside there.. and in order to replace it.. you have to replace the whole module? i dk .. lol.. I was just trying to explain to you what he said hehe..
In that diagram.. the fuel filter is obviously not even apart of the module, but according to dave.. it is supposed to be inside of the module. (at least from my understanding).
