Where's the best place for oil temp sensor?
Old Apr 25, 2002 | 03:03 PM
Michaelk's Avatar
Just bought an Apex Oil Meter with an electronic oil temp sensor, so now I want to know where to fit the moufou. Where should the sensor be fitted? In the sump or somewhere else?
Old Apr 27, 2002 | 10:46 AM
CliveW's Avatar
Personally I would fit it in the sump, normally most oil temp kits supply a probe and an adapter which screws into the sump in place of the sump plug. If not just take the sump off, drill a hole in an appropriate place and weld a nut on the inside with the same thread as the one on the temp probe. I had a disscussion with Evoboy on the MLR a while ago about this subject, here is the link;
http://www.lancerregister.com/cgi-bi...Page=&Session=
