i melted a coil pack!?
Old Jul 17, 2008 | 08:12 PM
black E's Avatar
i started the car this afternoon and it imidetly started missfiering, so i look at the plugs and all but one are perfect.... i look at the coils and one of them has a section on the side partialy melted! what the hell??
Old Jul 17, 2008 | 08:51 PM
black E's Avatar
is this normal?
Old Jul 17, 2008 | 08:56 PM
EvoHung's Avatar
Doesn't sound normal. What are your mods? Do you have a mini-battery?
Old Jul 17, 2008 | 09:01 PM
black E's Avatar
fp green, hks 264 IN 272 EX, ets UIP LIP , samco turbo inlet hose with blitz metal filter, hks DLI, greddy profc specII, TBE whit test pipe, FIC 750 inj , and yes brarille 15lb battery
Old Jul 17, 2008 | 09:13 PM
EvoHung's Avatar
If I can remember right, someone on here had their wire harness burnt and it might have been related to their mini battery. Something about the ground.
Old Jul 17, 2008 | 10:01 PM
scheides's Avatar
EvoM Moderator
Post pics!
Old Jul 17, 2008 | 10:40 PM
mikiblueeyes's Avatar
thats one of the **** Happens times, I happened to me 30K+ miles ago. I just replaced it with new one and no issues since.
Old Jul 17, 2008 | 11:10 PM
RazorLab's Avatar
I've seen a couple do that. It's not unheard of, I wouldn't say its 100% normal either.
Old Jul 18, 2008 | 09:53 PM
black E's Avatar
i'll post some pics tomorrow....
Old Jul 19, 2008 | 07:08 AM
Ivan@AMS's Avatar
Check the wire harness for the coils and the DLI very closely. See if there are any wires chaffed that may be touching metal. If the trigger wire is shorted to ground it will melt a coil like that. There is also a possibility that the DLI has an issue and is causing the issue. If you have a misfire with a new coil installed, bypass your DLI and see if it goes away.
Good luck
Old Jul 19, 2008 | 07:11 AM
silver9mr's Avatar
were the bolts on the coils tight? maby a loose coil pack and wasent making a good connection
Old Jul 19, 2008 | 09:46 AM
StevenStarke's Avatar
I have a set of coils for 150$ shipped, let me know if you need them
Old Jul 19, 2008 | 11:00 AM
black E's Avatar
yeah the bolts to the coil were tight and i already changed the burnt coil.
the car is fine now, no misfires or anything but i still what to make sure that i don't have a bigger problem causing this.
i did check the DLI harness for any exposed wires or anything else but nothing.
Old Jul 19, 2008 | 11:26 AM
black E's Avatar
any opinions?
Old Jul 19, 2008 | 11:31 AM
black E's Avatar
