loss in power after LICP?
Old Jul 19, 2008 | 05:38 PM
purekoryo's Avatar
I installed the ebay AMS knockoff LICP, the fitment was good, and during a test drive the pipe at the intercooler popped off since I forgot to tightened the coupling. After I tightened it, and did another test drive, it seems like there was a loss in power. The boost and power doesn't come on as quick as it used to when I had the OEM licp. Is it possible that the aftermarket LICP would decrease power? Lastly, I need to order some T-bolt clamps. What sizes did you guys order for the LICP?
Old Jul 19, 2008 | 05:46 PM
lexat20's Avatar
same size as there current clamp. Boost leak test and tune for the pipe and check back with us.
Old Jul 19, 2008 | 05:50 PM
DynoFlash's Avatar
Most likely you have created a boost leak - this is very common with lfmic pipes
Old Jul 19, 2008 | 06:01 PM
ItGoesTens's Avatar
Hope this helps...
Hope this helps with the clamp problem, sorry to hear about the boost issue.
Old Jul 19, 2008 | 06:02 PM
ItGoesTens's Avatar
^Click the pic to see full size^ sorry bout that
Old Jul 19, 2008 | 06:26 PM
huevosrancheros's Avatar
it looks like boost leak. I just installed my ETS LICP and I love it. Boost creeps in early and quicker. I installed my LICP w/ t-bolt clamps and everything is good to go.
I had a little bit of a problem installing it while under the car. I dont have a undertray on so I was able to get the pipe on there. Once I get my ETS intercooler I'll reposition it nice and proper.
Old Jul 20, 2008 | 05:34 AM
purekoryo's Avatar
actually, it was just in my head. my fiance test drove it herself (her car), and she said that it did noticeably spool quicker. I did, however, order some T-bolt clamps from ebay for the LICP (siliconeintake.com did not have the kit in stock). I think I'll order a T-bolt clamp for the throttle body as well since that is the biggest diameter pipe, most prone to popping off.
Old Aug 14, 2008 | 10:48 AM
Craig King's Avatar
Good to hear it was just in your head. I'm about to order one of these Ebay LICP as well. I already have the Samco upgraded silicon hose kit which uses hose clamps and I haven't had a problem with them popping off. As long as you tighten them, then re-tighten AFTER they heat up, you're fine.
I don't know why everyone swears by t-bolt clamps. I've seen bent IC pipes because someone OVER-tightened t-bolt clamps. As long as the pipes are beaded, you should be fine.
What's the difference between installing a LICP with or w/o tuning?
