Fuel Pump Question
Old Jul 20, 2008 | 04:45 PM
johnh954rr's Avatar
Fuel Pump Question
is the pump supposed to prime when the key is turned on?
Old Jul 20, 2008 | 04:57 PM
M3EvoBR's Avatar
yep !
Old Jul 20, 2008 | 04:59 PM
Ivan@AMS's Avatar
Yes, for a few seconds. Then it will turn off. When you turn the key to "start" it will turn on again.
Old Jul 20, 2008 | 05:12 PM
johnh954rr's Avatar
hmm ok cuz mine is not doing that and its having a hard starting problem
Old Jul 20, 2008 | 05:14 PM
ak47po's Avatar
Did you just install the pump?
Old Jul 20, 2008 | 05:21 PM
johnh954rr's Avatar
well i had a 255 in there for about 3 months and i just replaced it 2 days ago to make sure that wasnt it and the problem still remains. its having a hard start problem sometimes aftter it sits.
Old Jul 21, 2008 | 07:41 AM
neonglh's Avatar
It will prime a few times, and then once it has full fuel pressure, it will stop making that priming noise. If it doesn't do it the first time you go to the car, then something is most likely wrong. Does the car start afterwards, or just sits there and cranks?
Old Jul 21, 2008 | 09:17 PM
johnh954rr's Avatar
it will crank for about 4 to 5 seconds and then fire up
Old Jul 22, 2008 | 06:56 AM
diablo29d's Avatar
I'm having the same exact problem with my newly installed Fuel Pump. I just figured it might be the tune.
Old Jul 22, 2008 | 08:51 AM
LEvo77's Avatar
it should not take you 4 to 5 seconds of cranking before it fires up not on a stock ecu anyways, check your oring in the sending unit maybe you didint install the fuel pump correctly and your fuel pressure is not up to specs when being primed. Does it run normal when the car idles and you give it gas??? or is it chocking??
Old Jul 22, 2008 | 09:19 AM
diablo29d's Avatar
My car seems fine once it starts up, I haven't noticed anything else acting different. Checking the Oring is probably good advice, I had to replace it when I installed the pump because it was torn up. I'll do that and make sure it's sealing appropriately.
Old Jul 22, 2008 | 12:53 PM
LEvo77's Avatar
[QUOTE=diablo29d;5917218]My car seems fine once it starts up, I haven't noticed anything else acting different. Checking the Oring is probably good advice, I had to replace it when I installed the pump because it was torn up. I'll do that and make sure it's sealing appropriately.[/QUOTE
I have had lot of customers that had problems with those little orings weather it was damaged during installation or just from some sort of defect
Old Jul 22, 2008 | 05:39 PM
johnh954rr's Avatar
yeah mine ran fine for 3 months before this happened but i will check the oring also
