SAFR about 500 RPMS off...help me
Old Aug 20, 2003 | 05:07 PM
nastea's Avatar
my SAFR is about 500 RPMS off of what the tach displays, i connected it to what other people connected it to which is the crank or camshaft indicator i don't remember exactly but its what i found in the forums, which everyone is connecting too.
my question is how can i correct this?
Old Aug 21, 2003 | 05:29 PM
IzenGreyEvo7's Avatar
The Tach isn't always accurate. It all depends on which of the two has a higher sampling rate. Call HKS and see if they know the sample rate. It should be 400hz at the minimum. If I engineered it I wouldn't use anything under 16,000hz. But that's me. If it's a really low number then chances are the AFR is experiencing quantizing errors. If it's a higher number than 400, my money is on your tach being off.
Old Aug 22, 2003 | 08:56 AM
nastea's Avatar
thanks
Old Aug 22, 2003 | 06:20 PM
limey's Avatar
Didn't someone say to switch it to the 2 cylinder setting on this unit ...to get it in sync with stock tach. I thought I read something like that on this...could be wrong
Old Aug 22, 2003 | 06:47 PM
midwestmonster's Avatar
Yep. I have the S-afc II on my evo and it is on 2cyl. The rpms will match up. I even called Apexi to confirm.
Old Aug 22, 2003 | 07:01 PM
chinalfr's Avatar
Strange... I just install SAFC II on my car and I have the setting set to 4 cyl. The rpms match or at least close to match the car RPM.
So should I set to 2 cyl or use 4 cyl setting?
Darewood
Apr 20, 2011 03:26 AM
Chris@nolimitmotors
Mar 22, 2005 02:25 PM
forrest
Apr 15, 2004 11:39 AM
Trustz
Aug 27, 2003 03:22 PM
evo1
Jul 4, 2003 10:17 PM
