Car runs fine but........
Old Jul 22, 2008 | 01:55 PM
03silevo's Avatar
when under boost sounds like just air goin out the right side of engine???? Totally puzzled no intercooler hoses loose considering the car is running fine but when its just under boost just sounds like straight air coming out somewhere of course cant look under hood when happening......any suggestions would be great thanks
mike
Old Jul 22, 2008 | 01:56 PM
Evo8zip's Avatar
what does your boost gauge read?
Old Jul 22, 2008 | 02:05 PM
03silevo's Avatar
actually havent paid attention to the boost gauge more attn to the air fuel and thats fine
Old Jul 22, 2008 | 03:22 PM
holler mcdollar's Avatar
well he's asking because it sounds like you're talking about a boost leak.
but if your car is running/boosting fine, then you probably just have a super loud spool... tell us what you're boosting at vs. what you're supposed to be boosting at.
Old Jul 22, 2008 | 03:32 PM
AIEvo9MR's Avatar
Check all your intake and IC piping for loose clamps or torn rubber hoses. Its happened to me. Car runs fine when not under pressure from Turbo. Once the turbo starts building boost, your car starts choking. I had to reshape my LICP since it was bent.
Old Jul 22, 2008 | 03:41 PM
03silevo's Avatar
well i just put a 10.5 hotside and ported and coated my exhaust manifold and just got everything put back together........and been running fine for about a week now and someone thought it might have something to do with wastegate......any way i can check wastegate without taking it all apart
Old Jul 22, 2008 | 03:55 PM
Evo8zip's Avatar
well if the wastegate is opening early or just open period, you'd notice the loss of power and a low (compared to what it is set at) boost reading.
*sidebar, how do you like the GReddy RS? I have one sitting on my desk, need to have the flange welded on the UICP.
Old Jul 22, 2008 | 03:58 PM
03silevo's Avatar
no you can buy the flange from any shop and just bolts up to it and then goes in the uicp well it is a loss of power its NO BOOST at all sounds like just all the air it releasing
Old Jul 22, 2008 | 04:05 PM
Evo8zip's Avatar
sounds like either a major leak somewhere or your wastegate is stuck open.
Old Jul 22, 2008 | 04:15 PM
03silevo's Avatar
okay well thanks for your help any suggestions on how to check either one of them problems
Old Jul 22, 2008 | 04:33 PM
Evo8zip's Avatar
you can do a pressure check of the system to find a leak...there are how to's on here, never have had to do it myself.
