Engine management for my Evo 6.5 ?
Old Jul 27, 2008 | 12:40 AM
lancebin's Avatar
Hi folks,
I've been reading that the ECU of the evo 6 isn't programmable? Does this mean I do not have the possibility of having it reflashed? What options do I have without going to a full standalone? Probably emanage blue? Would love to hear your suggestions. I only plan on upgrading my exhaust to 3" along with a few minor addons.. possibly aiming for 280-300 whp. Thanks!
Old Jul 27, 2008 | 01:59 AM
joyce1bro's Avatar
yes you cannot flash your ecu. you will need to get an evo 7 or 8 ecu and change a few pins to get it to work so that you can flash or tune your car. Personally i dont like the e-manage waste of time and money unless you get the e-manage ultimate (which is not standalone).... but you could get alot more for your money going with a 7 or 8 ecu that does the same job. 300hp is not major numbers so a 7 or 8 ecu is more than good for that.
Old Jul 27, 2008 | 09:07 AM
lancebin's Avatar
Ok thanks mate, will try to ask around on how much an Evo 7/8 ecu costs here.
Old Jul 28, 2008 | 02:38 PM
E5_DCB's Avatar
With your mods why not fit a Ralliart ECU?
Has a more aggresive map and no boost cut.. Its just a plug and play ECU no messing about with wires ect ..
You can run 1.6Bar with a good boost controller and with your mods about 350 - 370 BHP fly..
Old Jul 28, 2008 | 04:31 PM
joyce1bro's Avatar
why would you spend alot of money getting a ralliart ecu when you can just buy a evo 7/8 ecu and flash the ralliart into it... so much cheaper. you cannot flash a ralliart ecu unless you pay more money to unlock it....
Old Aug 3, 2008 | 02:26 PM
E5_DCB's Avatar
I had the evo 7 ecu in my car for awhile with the ra patch.
The car kept cutting at at 70mph
Turned out to be the e7 ecu at fault..
E7 ecu has a added safety feature where it will cut the engine if it detect alot of vibration from the knock sensor..
Old Aug 3, 2008 | 03:35 PM
EE's Avatar
EE
e7 ecu is better than the e8. Only one pin or two to change.
I had an evo 6 before my evo 9, i once plugged an e7 ecu bcs it has the fuel cut at higher boost. I didn't know abt ecuflash back then.
I think this is the way you need to go
lexa609
Lancer Engine Management / Tuning Forums
Jun 16, 2015 12:51 PM
black_beauty
21
May 20, 2015 02:11 AM
EmirEvoEight
12
Sep 9, 2014 04:01 AM
KOOLER
Sep 3, 2010 12:28 PM
lousEVOxmr
Aug 10, 2009 08:17 AM
