plug blew out
Old Jul 29, 2008 | 01:27 PM
mdsevo06's Avatar
Machine shop can fix it, but the Head has to come off. You'll need to flush as much off the particles out off the combustion chamber and around bearings before re-assembled.
Edit: Keyserts would be a better option.
Old Jul 29, 2008 | 01:30 PM
Wicked E's Avatar
Here's some good reading on Heli-coils
http://www.roadstarmagazine.com/modu...rticle&sid=233
-E
Old Jul 29, 2008 | 01:32 PM
fknlowpsi's Avatar
y does the head have to come off to do it right??? thanks guys for your help
Old Jul 29, 2008 | 01:59 PM
mdsevo06's Avatar
The difference between Heli-coils and Keenserts/Keyserts, is the ability to rotate an insert. Keyserts are designed with four KEY features to prevent this from happening and are preferred in Aerospace, Naval and any other application that requires a far superior insert. Specifically designed for Aluminum application and since the head has to come off, why settle for less.
Old Jul 29, 2008 | 02:10 PM
fknlowpsi's Avatar
anybody running a helicoil ??
Old Jul 29, 2008 | 02:30 PM
fknlowpsi's Avatar
will this work??
http://www.denlorstools.com/home/dt1..._spark_pl.html
Old Jul 29, 2008 | 02:33 PM
rdwngs44's Avatar
same thing happened to me... blew plug busted spark cover and destroyed last couple of threads in head. so i tapped and now good to go no issues what -so -ever!
Old Jul 29, 2008 | 02:36 PM
fknlowpsi's Avatar
what kit did you use rdwng????
Old Jul 29, 2008 | 02:37 PM
mdsevo06's Avatar
Originally Posted by rdwngs44
same thing happened to me... blew plug busted spark cover and destroyed last couple of threads in head. I sent a magnet down and there weren't any metal shaving so i tapped and noe good to go no issues what -so -ever!
Aluminum?
Old Jul 29, 2008 | 02:43 PM
AF-Evo8's Avatar
Originally Posted by mdsevo06
Aluminum?
he had a "special" aluminum magnet
Old Jul 29, 2008 | 02:45 PM
mdsevo06's Avatar
Sticky
Made out of Bubble Gum
Old Jul 29, 2008 | 04:07 PM
Johnboy1065's Avatar
because if you don't take it off you'll be getting a lot of metal shavings inside the cylinder. kinda bad for your engine
hotshot1
96
May 14, 2011 07:08 AM
mtm864
Feb 21, 2011 06:55 PM
blackevo110
Jul 28, 2007 12:18 PM
tougetuned
Mid-Atlantic Region
Mar 14, 2007 10:05 PM
