Boost issues
Old Jul 28, 2008 | 07:56 PM
M3EvoBR's Avatar
Boost issues
I have an AVC-R, and even if I try to raise the duty cycle to 90% and raise my boost levels above 30 psi, I can't see anything more than 29 psi and tapering down to 28.
And when I download my logs from my AEM, the AEM map sensor reads differently from my apexi gauge and the AVC-R. In the AEM can't see anything more than 25 PSI for a few seconds, even in forth gear.
Any help ???
Should I go back to Manual boost controller ????
Old Jul 28, 2008 | 08:17 PM
RazorLab's Avatar
Which BOV are you using? A leaking BOV will limit your peak boost.
Old Jul 28, 2008 | 08:36 PM
M3EvoBR's Avatar
hum .... I'm using a Tial blow off
Old Jul 28, 2008 | 09:49 PM
sparky's Avatar
I think that Razor is probably on the right track. You can test this theory by sandwiching a sheetmetal block-off plate in between the BOV's inlet face and the IC pipe flange. Just use the BOV's gasket as a template and drill the two bolt holes out.
EvoDan2004
28
Oct 25, 2013 07:58 PM
Boostin4life
Aug 4, 2010 04:37 PM
lutch
Jan 23, 2009 04:25 AM
jcsbanks
12
Oct 29, 2007 01:21 PM
CrackerJackToy
Aug 11, 2007 06:54 PM
