Evo MR Full Fluid Change.
Old Aug 7, 2008 | 02:51 AM
PineappleMonkey's Avatar
About to flush out all my fluids and this is what I'll be going with.
Engine: Amsoil
Transmission: OEM
Transfer case: diaqueen
Rear diff: diaqueen
Clutch/brake: motul rbf600
coolant: Oem
Old Aug 7, 2008 | 03:00 AM
19DB794's Avatar
Engine: Amsoil
Transmission: OEM
Rear diff: diaqueen
coolant: Oem
I also had my transmission, rear diff and t case flushed with oem fluids at 13K miles and it shifts nice and smooth compared to what it was. Although it wasnt that bad before but I definatly felt a diffrence and still do.
Old Aug 7, 2008 | 04:02 AM
4drboost's Avatar
I only put what Mitsubishi recommends..........OEM fluids
Old Aug 7, 2008 | 06:45 AM
justboosted02's Avatar
Originally Posted by Pure Playaer
yo what do u do now? what about the front diff?
front diff is in transfer case
Old Aug 7, 2008 | 06:52 AM
EvoDan2004's Avatar
Car's currently at about 18,300 Miles.
Oil : Redline Full synthetic Oil. here i would use factory oil or amsoil only
Clutch Fluid: Not Changing ATM. i would change it. but this is done when you do your brakes as it shares the same ressiware
Transmission Fluid: ?? (OEM) ?? use oem or bg synocroshift II.
Transfer Case Fluid: ?? (OEM) ?? oem only
Brake Fluid: -Edit- Probably not changing. Unless someone suggests to. i use motul RBF works awesome. but you have to change it often
Rear Diff: 1 quart Redline Heavy Shockproof w/1.0 ounce of Redline LSD Additive.......... i would only use oem in the rear diff to
Front Diff: ?? Same as rear?!?! i dont have afront diff so idk. tcase?? oem only
Coolant: OEM or depending when you drive your car you can do some custom mixes... but make sure no mater what you put a bottle of water wetter in. helps out alot.
Should i use the same for the front diff, as i should for the rear?
Old Aug 7, 2008 | 10:01 AM
Erik@MIL.SPEC's Avatar
Please do yourself a favor and do not put BG II in your 6 speed.
Old Aug 7, 2008 | 10:17 AM
Pure Playaer's Avatar
thanks for the suggestion guys!
Old Aug 7, 2008 | 10:18 AM
JordanS4's Avatar
That's great for an OEM car but not one with 500+ whp that sees track time.
Old Aug 7, 2008 | 10:23 AM
JKD's Avatar
JKD
Engine: German Castrol 0w-30 (germany)
Brakes: ATE Superblue
Trans: OEM Diaqueen
Tcase: OEM Diaqueen
Rear: OEM Diaqueen
Old Aug 7, 2008 | 12:20 PM
EvoDan2004's Avatar
oops. my bad. i dident know he has a 6 speed. i thought 5 speed. no do not use bgII in a 6 speed trans.
Old Aug 7, 2008 | 01:16 PM
Granted some people do 5 speed swaps, but the title of this thread is "Evo MR Full FLuid Change."
Old Aug 11, 2008 | 04:47 PM
So Diaqueen for the transmission and transfer case?
Is Diaqueen just mitsubishi oem stuff or do i have to order it? or ask for it special from mitsubishi
Old Aug 11, 2008 | 04:51 PM
JordanS4's Avatar
How do you have 2,000 posts and you don't know simple **** like this?
In the t-case put Diaqueen. In the trans put Super Diaqueen or Redline.
Old Aug 11, 2008 | 04:55 PM
Personally, I would put something more durable in the TC than the Diaqueen. I switched to Redline Heavyweight Shockproof after seeing way too much metal in my TC fluid.
And, you know my thoughts on the MR tranny fluid
Old Aug 11, 2008 | 05:02 PM
Erik do you put 100% redline heavyweight shockproof in your transfer case? or do u put something in addition to it? Also what do you suggest for the tranny? Same thing?
Im putting redline heavyweight shockproof + LSD add. in the rear diff.
