To Stroke or Not to Stroke
Old Jun 5, 2009 | 01:38 AM
  #76
Pohjeekiller's Avatar
To stroke or not to stroke....
Old Jun 10, 2009 | 10:29 PM
  #77
voloracer's Avatar
Originally Posted by 9sectalon
Love my 2.3l with the GT35R. ENJOY!
Are you stroked? If so what kind of hp are you throwing down? In the process of stroking the engine right now and looking for a good turbo to throw on...
Old Jun 10, 2009 | 10:37 PM
  #78
Johnboy1065's Avatar
I run a HTA 3586R with a 2.3 liter, numbers should be coming soon!!!
Old Jun 10, 2009 | 10:42 PM
  #79
voloracer's Avatar
Nice, I'll be interested to see what kind of numbers you pull. Let me know...
Old Jun 12, 2009 | 02:57 PM
  #80
toverton30's Avatar
Great info!!!!!..
Ps im looking for a 03 T-case
Old Jul 12, 2009 | 08:36 PM
  #81
slowr_evo's Avatar
stroke it dont beat it!! but good info
Old Jul 25, 2009 | 10:04 AM
  #82
mitsuclipsegsx's Avatar
I had my eclipse stroked. it was nice on the street with a 50 trim, but if I were to do it again I would of done a built 2.0
Old Aug 25, 2009 | 10:29 AM
  #83
DragEvo9's Avatar
Stroke it brooooooooooooo
Old Aug 26, 2009 | 07:47 PM
  #84
RapedApe's Avatar
I bought my Evo with a 2.3L and bb 50 trim. If you are going stroker, don't waste your time on anything smaller than a 54 lb/min turbo. I personally will upgrade to at least 65 lb/min. This 50 trim with .63 housing makes 356 tq at 4700 and 351 hp at 5700 on a mustang dyno. HP drops to 320 at 7200. The car has stock head with HKS 264/272 cams. The turbo just can't keep up with the 2.3 and you can feel it.
Old Aug 27, 2009 | 07:39 AM
  #85
nic3boy's Avatar
4g64 2.5l strocker
Old Sep 12, 2009 | 08:20 AM
  #86
kevin8086's Avatar
great info
Old Oct 8, 2009 | 03:56 PM
  #87
bLk-Ev0-aTe's Avatar
very informative.
Old Oct 15, 2009 | 01:40 PM
  #88
Thomasevo's Avatar
stroke it 2.3L rocks
Old Nov 16, 2009 | 12:49 AM
  #89
kjewer1's Avatar
Originally Posted by JohnBradley
I also do not believe nitrous helps spool, it only helps off spool power which means it gets to where the turbo would normally spool faster than without.
Old thread found while searching I know, but for the sake of the archives... Nitrous definitely does help spool. I agree with your reasoning above for increases in CR, but remember that nitrous is more air and more fuel burned at that same rpm, which results in more exhaust product, which results in a lower boost threshold. It's the same thing as increasing displacement, more exhaust product per rpm level. In fact I think one could make the arguement that if you add 20% of your power with nitrous the effect on boost threshold is the same as a 20% increase in displacement. I used this theory to calculate the increase in fuel requirements with a dry system on my car and it worked out to within the accuracy of my horsepower measurement at low rpm.
On the automatic the benfit is two fold since the added torque also gets you higher up on the converter making more boost, but that conversion is unlikely to interest anyone here.
Old Dec 10, 2009 | 04:14 PM
  #90
stwhollywood's Avatar
has anyone de-stroked an engine? Like with the principals of a formula 1 racecar? make the pistons not move far at all, but move a lot? seems like you would rev REALLY high that way and make good power and torque? i might be way wrong, just seemed cool and didnt know if anyone had done it or even looked in to it
