Camshafts for Evo red... idle, revlimit, power
Old Aug 14, 2008 | 10:18 PM
omniprobe's Avatar
I would say jun 272 or the kelfords.
Also if your on the Red there's no need to rev to 10k , power falls off before then.
Old Aug 14, 2008 | 11:10 PM
Erik@MIL.SPEC's Avatar
Originally Posted by markymark1082
Some people have started to think that Kelford and GSC cams are the same with different names. Just a thought.
Even if Kelford may produce the GSC cams, I am not sure the grinds are the same.
Old Aug 15, 2008 | 12:01 AM
john.schuber's Avatar
I would definitely get head studs that's a no brainer i apologize for not mentioning it. I don't understand what's so bad about an aggressive cam. I've heard that JUNS are much more of a problem getting them under control with a viii without a standalone, but a ix is pretty easy to get a nice idle even with the stock ecu.
So what other downsides do aggressive cams? I know 9sec9 runs the red and the juns and he's the one that recommended kiggly racing springs and retainers. I have also heard the GSC S2's have put some serious numbers up on stock frame turbos and S2's really don't need a 35r or bigger to maximize their potential.
Old Aug 15, 2008 | 12:04 PM
Ted B's Avatar
More aggressive cams create more sluggish low speed response and spool characteristics, while placing greater stress on the valvetrain.
At the very least, cams should be matched to the realistic capability of the head and turbo. The port of a factory head is dead above ~10.5mm lift, so JUNs seem to be designed around that. With respect to effective duration and cam timing, ideally one wants something that begins coming on at the same time as the turbo, and signs off about the same time. Anything else, and the car goes slower.
As a rule of thumb, it's better to under-cam slightly than to over-cam.
Old Aug 15, 2008 | 04:59 PM
So you would recommend the GSC2 unless I get a headwork done? Springs and retainers won't cut it?
Old Aug 15, 2008 | 07:44 PM
4G63W8's Avatar
guys what's your opinions on the red with the hks 272??
Old Aug 15, 2008 | 07:49 PM
Shacochis06's Avatar
not aggresive enough
Old Aug 15, 2008 | 07:55 PM
4G63W8's Avatar
Ok,how about the green and the hks272? Is that a good combo?
and what cams for the red,i've heard the kelford ones are pretty good!
Old Aug 15, 2008 | 08:02 PM
4g63smokinall4s's Avatar
Originally Posted by deadbeatrec
WAT?
first off, is this english?
u dont want to go with dual springs because of the excesive wear on the valvetrain unless u plan on running really high in the RPM range. i would say 8500 is just fine with single springs. the red will die off well b4 10k as well, and u are crazy if u are running 10k on a stock bottom end!!!
This is the smartest post ive seen in this thread and is entirely correct!
BTW if you can afford the Juns they are a sick cam but then again so are the S2's i see your dilemma! GL
Old Aug 15, 2008 | 08:28 PM
EVIL MR's Avatar
Same here.
Old Aug 15, 2008 | 08:44 PM
does anybody know how much the juns really cost....i found a vendors website on here and on there website they where like $1200 i mean i know there a sick cam but the price kinda sounded rediciolous for a cam...anybody know the real price
Old Aug 15, 2008 | 08:45 PM
JUN = teh $$$$$$$$$$$
Old Aug 15, 2008 | 11:35 PM
thatdudety's Avatar
kelfords are good too. made me think twice b4 buying the cam i had in mind
Old Aug 15, 2008 | 11:59 PM
evo9 ate u's Avatar
cosworths are good cams for the IX thats what i suggest
Old Aug 16, 2008 | 12:48 AM
$1200 i think includes springs and retainers with the cams. I'm pretty sure just the JUN camshafts are around 800 or so. Can anyone answer my question about getting the S2's unless I do all the headwork then get the JUNS. Is it really not advisable to run Juns with just head studs, springs, and retainers.
