Can a SAFC read boost pressure?
I asked this question in another post, but didn't get much response. I was told that a SAFC does not read boost pressure. If so, then what is meant by the description on Apex website (http://www.apexi-usa.com/electronics_safc.asp):
"The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure , Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %." Does the EVO ECU not have the required pin connections that would be used to connect the SAFC, to utilize these functions? Any Evo owner who has one of these units can you tell me if they do truely read boost pressure, and if so how is it read; bar or psi? In any case I will be purchasing one shortly, and I want to also be able to read boost and wanted to know if I need a boost gauge as well. If I do ultimately need to get a gauge as well, what is a good inexpensive boost gauge I could get that might have a back light, glow in the dark, or indiglo that I would be able to read at night? Thanks.
that as far as i remember is a setting so you can vta with a maf system and not bog it tells ecu correct air flow after the vent so you dont bog. Correct me if im wrong guys?
Sicktght311
Lancer Aftermarket Forced Induction Tech
42
Mar 30, 2018 01:13 AM
abuelo ralliart
13
Sep 25, 2009 01:42 PM
EVO MR FU
Nov 15, 2005 05:09 PM
NITROHEAD
Feb 22, 2005 02:34 PM
