Should I get headstuds or can I wait?
Old Aug 18, 2008 | 10:25 AM
EVOIXreno's Avatar
I am installing Brain Crower 280 cams, a fuel pump, injectors, and an exhaust. I will be getting tuned at 23ish psi and Wont be at the strip but once every couple months at most. Do I need headstuds or can I wait until I go to a red? TIA
Cory
Old Aug 18, 2008 | 10:31 AM
Hikaru's Avatar
get them now while the head is off the car
Old Aug 18, 2008 | 10:36 AM
dudical26's Avatar
1st - The head does not come off the car when you install cams
2nd - you do not need head studs on an Evo IX running 23 psi
I run 31 psi on stock headstuds with no problem.
If you are running less than 25psi you absolutley don't need head studs.
Old Aug 18, 2008 | 10:46 AM
EVOIXreno's Avatar
One other Question...Do I really need the injectors. I am not trying to max the car out...just want something a little faster than what I have now!
Old Aug 18, 2008 | 10:53 AM
gsrboi80's Avatar
Injectors wont make your car faster . You dont need them untill you upgrade your turbo, your running E85, or your running out of fuel up top
Old Aug 18, 2008 | 11:05 AM
EVOIXreno's Avatar
Thank you very much!
Old Aug 18, 2008 | 11:10 AM
Billy@EnglishRacing's Avatar
you do not need them, wait
Old Aug 18, 2008 | 12:11 PM
EVOLVEU's Avatar
Id get them because if you are modding now, you'll probably want more power later on, so do them now while it is convenient.
Old Aug 18, 2008 | 11:26 PM
SpeeDeviL's Avatar
^^^+1
Old Aug 18, 2008 | 11:35 PM
EvoHung's Avatar
Do not get them unless you pull your head off of the block. Stock studs work pretty well unless your running well over 23 psi. But for some reason you have already pulled the head (as noted above, cam install does not require head to be pulled) then go ahead and install the arps, why install stock when you can install arps right?
Old Aug 19, 2008 | 05:40 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
You know what get them now since you plan on doing a red down the road. At least if you do the studs now one less thing for you to worry about later and when you get the red you can just bolt it on and take your injectors to your local shop have them install the injectors and retune u for the red. So yes to studs now no to the injectors unless your running E85 or bigger turbo then stock 9
Old Aug 19, 2008 | 05:45 AM
mitsudave's Avatar
Get heasdstuds. It is not expensive and totally worth it. You WILL run more power eventually so do it. Enjoy
Old Aug 19, 2008 | 05:54 AM
jmelocik's Avatar
Head studs are cheap insurance , injectors can be scaled back, why not get them now so you can turn up the boost later on? I am from the mind frame of "do the mods that protect the motor first, then build power later" Just my .02 worth.
Josh
Old Aug 19, 2008 | 07:16 AM
justboosted02's Avatar
if you get headstuds, you WILL be pulling the head off. if not when you install them, then later down the road to fix your weeping head gasket
Old Aug 19, 2008 | 07:38 AM
compscibOi's Avatar
Josh
Exact same mentality as me. If you are going to be in the engine, why not just do them? No you don't NEED them at 23 lbs of boost, but eventually if you are going to do it, you might as well just do it now. It won't hurt anything, it will actually help. They cost a whopping $99 bucks. Cheap insurance IMHO!
