Should I get headstuds or can I wait?
Old Aug 21, 2008 | 12:41 PM
  #46
STIKILLA1084's Avatar
Get the headstuds.Its cheap and if u know you're going to up boost someday, u cant go wrong.
Old Aug 21, 2008 | 01:04 PM
  #47
hytek369's Avatar
And how often do stock head bolts fail? It's extremely rare and most often caused by detonation, not high boost. Backside oil leaks from installing ARPs with 1X1 method are far more common than failed stock head bolts...
OP, don't waste your money. stock is fine. If you want them, buy my ARP studs. I decided not use them, based on the reasons Warrtalon listed here.
Old Aug 21, 2008 | 01:32 PM
  #48
Warrtalon's Avatar
Originally Posted by justboosted02
Funny how on one side people are arguing to just spend the $99 for "safety" while doing the 1x1 method blindly, then on the other side I have people telling me NOT to spend a little extra to get the absolute best studs when removing the head to do it properly. Can't win for losing. I will be using my stockers until the head comes off...
Old Aug 21, 2008 | 06:16 PM
  #49
whitey4d's Avatar
Originally Posted by 1NastyMR
Ya but you need to remove the cams to put the studs no? so why have to remove cams twice
actually no you dont. There not "cam over bucket" like Toyotas and Nissans etc. There have hydraulic lifters the rockers ride upon.
Old Aug 21, 2008 | 08:00 PM
  #50
justboosted02's Avatar
and that is what you should do, as the people that do the 1X1 are cutting a corner that is gonna bite them in the *** later. you of all people done need me to tell you that
however, standard arps are more than enough. but some people only want the very best and would purchase the L19s over standard and that is fine. but i need proof that the standards are inadequate before i buy the L19s.
Old Aug 22, 2008 | 12:58 AM
  #51
dsmfan95's Avatar
With the Green you might want to grab a set. I started pushing coolant with the Green @ 29psi.
Old Aug 22, 2008 | 03:37 AM
  #52
sparky's Avatar
What do injectors have to do with headstuds? What do headstuds have to do with a camshaft upgrade? This thread is nutty!
polish_pounder
Aug 13, 2011 03:45 PM
kemoly
10
Aug 7, 2009 05:35 PM
supercharged
Aug 1, 2008 12:31 PM
Nomad4g63
16
Jan 14, 2008 04:15 PM
ihatepotholes
14
Oct 27, 2006 01:56 PM
