AC took a dive...HELP
Old Aug 18, 2008 | 11:35 AM
PsychDr. HN$'s Avatar
Sup yall. i hope that this is the correct section for this. eitherway, i was driving the other night with the AC on and it was blowing ice cold. The very next day i get on the interstate and when i turned on the AC on it blew cold for a few minutes then it just started blowing hot air?!? I took it to a friends shop and here is what I know;
*** Fans work
*** AC lines were full and still had/have pressure
*** We checked ALL of the fuses and relays
*** He was able to turn the compressor by hand so it isnt locked up (I guess)
*** He got a wiring diagram and it showed two leads going to the compressor. According to the wiring diagram ONE of the leads is supposed to read POSITIVE while the other reads NEGATIVE. FOR SOME REASON both of my wires were reading POSITIVE?!?
*** He is thinking that maybe the AC clutch is gone bad or the temp sensor inside the compressor is bad. Eitherway, it looks like I will need a new AC compressor
Do yall have any other ideas or suggestions that i can try or look for before i buy a new compressor? ATL HEAT+NO AC=
Old Aug 19, 2008 | 09:33 AM
bump
Old Aug 19, 2008 | 09:39 AM
justboosted02's Avatar
move north????????????
if you do need a compressor try to find a used one in the for sale forums, cause from the dealer they are $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old Aug 19, 2008 | 09:41 AM
yes they are kinda pricey. IF i do need one hopefully i can scoop one up in the FS section from one of the big turbo guys
Old Aug 19, 2008 | 09:44 AM
Curt@MrLed's Avatar
Former Vendor
I would say a temp switch went bad. Easiest bet is a scantool.
Old Aug 19, 2008 | 09:55 AM
where would that temp switch be located? i was told that it is inside of the compressor?!?
btw, do u still paint the oem tails? i got a extra pair from an 2003 that i want to get painted like the evo ix tails. if so pm ur price to 30094
Old Aug 19, 2008 | 10:33 AM
Can someone chime in on the temp switch? its location? cost of replacing it?
Old Aug 19, 2008 | 10:58 AM
denver89's Avatar
03 black evo here same thing happend to me exatly everything is gettin power no leak just hot air
Old Aug 19, 2008 | 11:01 AM
denver89's Avatar
Possibly the round brown thing that the other wire goes to thats held in by a stupid snap ring and i beleive if u take it out ur pressure goes by by
Old Aug 19, 2008 | 11:02 AM
self bump
Old Aug 19, 2008 | 11:03 AM
denver89's Avatar
i already bought a compressor but is used and its alota money and time to but the new 1 on and it not work either at least or me anyway i wish winter would hurry up
Old Aug 19, 2008 | 11:49 AM
wkehn's Avatar
Pressure switch is on the pass side of the car off the AC line. Mine has been doing the same thing and after ruling out the temp switch it appears to be the AC clutch not engaging despite getting a signal.
Old Aug 19, 2008 | 12:08 PM
thanks. Which one of the two are on the pass side of the car? The pressure switch or the temp switch?
Old Aug 19, 2008 | 01:05 PM
ny-quiL's Avatar
My AC just recently blew up on me - sucker seized up and make quick work of my serpentine belt - 80$ flatbed ride and 20$ AC-delete belt from napa was the cure.
Old Aug 19, 2008 | 01:14 PM
wkehn's Avatar
Sorry for not clearing that up. The dual pressure switch is on the pass fender area on the ac line. I don't have my diagram at the moment to see where the temp switch is but it could be contained in the AC ecu.
