AMS 2.3rr and Cosworth 2.2 short block
Old Aug 18, 2008 | 05:44 PM
EVOlutionary's Avatar
There are a few suppliers of custom TI rods for the EVO. I know of a couple motors running them. For the TI rods alone you can expect to pay $2500-$3500 . . .
Old Aug 18, 2008 | 05:50 PM
M3EvoBR's Avatar
thanks for the reply, but can those TI rods handle power and time :???
I know that my crower set of TI still running since 2003 ...
I think I had a great deal at the time. Like 4000,00 US Dollars (here in Brazil)
Old Aug 18, 2008 | 05:52 PM
BTW, the new Vette ZR1 uses TI rods . . .
Old Aug 18, 2008 | 05:55 PM
Erik@MIL.SPEC's Avatar
The Cosworth pistons are produced in-house. They have their own special process for making them. Aby knows what the process is called, as he told me (but I forgot).
Old Aug 18, 2008 | 06:27 PM
tkuoha's Avatar
awesome info, does anybody actually own either?
Old Aug 18, 2008 | 06:38 PM
mtevoracer's Avatar
Originally Posted by Jasil
Smoking tons of crack if you buy a 9K shortblock!!! You can buy some carbon fiber rims to go with it.
+1 that's funny. On a serious note though the 2.3rr has gone up to 9100 on that car from denmark.
Old Aug 18, 2008 | 07:34 PM
ecuflasher's Avatar
Originally Posted by Ted B
Possibly K1 crank and rods as well. That would definitely be a bit less pricey than Carillo and a $3300 domestically-made (I presume) billet crank. Is the difference worth it? That is a consumer decision.
K1 told me that their parts are manufactured in China and finished in the USA. I have seen their rods and the finishing on them is worse than the Eagles or Manleys. Their 4G63 crankshaft looks good though but requires custom fitting of main bearings due to its fillet radius
Old Aug 18, 2008 | 07:39 PM
ecuflasher's Avatar
That said, I would go for the AMS 2.3RR over the Cosworth 2.2. If you are open to dealing with other shops, then the JAM 2.3 stroker would be my recommendation.
Old Aug 18, 2008 | 07:48 PM
BTW, I checked with Aby and he said the Cosworth pistons used to be squeeze cast, but he's not positive that's still how they make them (he once worked there, but it has been awhile).
Old Aug 19, 2008 | 07:24 AM
Lars Denmark's Avatar
Hey Guys,
I have a AMS 2.3RR engine and a Cosworth 2.2 enginge.... both engines are great
I am reving the 2.3RR engine to 9550 rpm. when I am dragracing with it.
The Cosworth 2.2 engnie I am using in a daily driving Evo and I am reving it to 9.000 rpm.
If I should choose between these engines I will those the AMS 2.3RR engine with no doubt....
My fastet time is 9.30 @ 150 mph with the 2.3RR engine.
http://www.bilgalleri.dk/html/vid_vis.asp?VideoID=18012
Old Aug 19, 2008 | 08:03 AM
SpunEvoIX's Avatar
you can also look into the magnus 2.2 stoker kit...it has pauter rods and ross pistons and a billet crank.... thats what i am running right now and i rev it to 9,000 rpm no problem
Old Aug 19, 2008 | 09:19 AM
Ted B's Avatar
I hope you have good brakes, because at that speed, it won't take you long to run out of land in Denmark. That's what you deserve for having an abundance of naturally blonde women, a sex museum, good beer, aquavit, E85, and all those things that suck.
Maybe we can do some trading. . .
Old Aug 19, 2008 | 09:41 AM
Solo II Evo's Avatar
Awesome. EU FTW!
jmartinez1170's Avatar
AMS just becasue all the testing that went behind that motor setup. And its track proven.
Cosworth im sure they use a engine dyno for there testing as they do with there F1 motors. Which i feel is not the same as having it in the car and taking it to the track for R&D. Not saying that dont do it. But at the same time it might be done on a test track vs actual tracks with far more range of tuning as not all tracks are ran on the same tune.
Old Aug 19, 2008 | 10:10 AM
hokiruu's Avatar
I can't verify this 100%, but someone who I consider a pretty reliable source of information recently posted here that the AMS 2.3RR uses a 4G64 block. Can anyone verify or disprove this?
