AMS 2.3rr and Cosworth 2.2 short block
Old Aug 18, 2008 | 03:06 PM
tkuoha's Avatar
The Cosworth costs a lil more but is it really better than the 2.3rr??? Anyone have any experience with either, or has a comparison been done?
Old Aug 18, 2008 | 03:09 PM
SpunEvoIX's Avatar
a little...yeah right the cosworth is 9 grand but its a hell of a block and quality (not ssaying that ams isn't) and you can rev it to alot more than the 2.3 prob till like 9,000
Old Aug 18, 2008 | 03:32 PM
tkuoha's Avatar
does anyone even have a cossie short block???
Old Aug 18, 2008 | 03:52 PM
M3EvoBR's Avatar
wich part of the cosworth is better than the others ???
Old Aug 18, 2008 | 03:53 PM
M3EvoBR's Avatar
better than Pauter rods, with CP or wiseco pistons ???
Old Aug 18, 2008 | 03:54 PM
Jasil's Avatar
Smoking tons of crack if you buy a 9K shortblock!!! You can buy some carbon fiber rims to go with it.
Old Aug 18, 2008 | 03:56 PM
pbevo12's Avatar
guess u missed the RR ,in that its 8k so ya 9k would be a littloe more ,and it also revs out pretty high for 2.3 block
Old Aug 18, 2008 | 04:14 PM
Ted B's Avatar
A basic comparison should be straightforward.
Both appear to use a new block, as I see no core request for AMS' part.
Both obviously are fitted with quality pistons, Ross for AMS and Cosworth's own design for themselves. Cosworth wants over $1000 for their piston set.
Bearings would be ACL for Cosworth, Clevite for AMS. AMS' rotating assembly parts look to be especially engineered for mass reduction.
Both describe a 'custom billet crank' with 94mm stroke. Cosworth wants $3300 for their crank, AMS does not list the one they use individually. The Cosworth crank is expensive, and I would expect nothing less than a domestically-made crank for that price. AMS describes theirs as a billet crank as well. Eagle lists a forged (not billet) 94mm crank that I believe is Chinese made, and lists for $873, so I would expect neither Cosworth nor AMS to use this crank given the cost and the parts descriptions. You may want to ask both where their crank is actually made (not finished), and in the case of AMS, what it costs individually. Not so much that it really matters aside in what you get for what you give.
Cosworth's connecting rods are described as forged (not billet), and are listed at $1000 per set. AMS' rods are described as billet, and are not individually listed. AMS gives a rod bolt upgrade as well. Again, at $1000 for a set of Cosworth's forged rods, I would definitely expect something other than a Chinese made rod, so you may want to inquire specifically. For the sake of comparison, $1000 is what it costs for a set of custom, domestically made billet rods.
AMS' assembly includes, new oil pump, new water pump, and machined 'race' balance shaft, and AMS o-rings the deck. All together, this is somewhere north of $500 in value.
The AMS assembly is listed at $8000, Cosworth at $9300.
This is about as far as it goes from this vantage point. You'll have to call with very specific questions to obtain more info.
Old Aug 18, 2008 | 04:16 PM
Ted B's Avatar
Pauter is a forged rod. The Cosworth rods are listed as forged rods. Forged rods are not as strong as a good billet rod, so neither represent the best possible choice.
Old Aug 18, 2008 | 04:39 PM
ecuflasher's Avatar
Cosworth shortblock should be using Carrillo H beams and I suspect AMS might be using the K1 lightweight billet crankshaft
Old Aug 18, 2008 | 05:17 PM
kouzman's Avatar
I believe Carrillo builds the rods for Cosworth. we should research that...
I know that Cosworth blocks are revved up to 10,000rpm with no ill effects.
Nothing against AMS, i love them as a company but if i was to spend that money i would go for Cosworth. Trust them no questions asked because of YB Ford Cosworth background...
People with 2.2 Cossie strokers would chime in for feedback...
Old Aug 18, 2008 | 05:23 PM
M3EvoBR's Avatar
nobody uses Titanium rods on Evos ???
I used to have Crower titanium rods on my VW.
I know that billet aluminun rods are very strong but, as far as I knw they don't last too long
Old Aug 18, 2008 | 05:27 PM
SeanC's Avatar
This is correct.
Old Aug 18, 2008 | 05:41 PM
andy hiralall's Avatar
I know for a fact that Carrillo builds the rods for Cosworth!!!!
Old Aug 18, 2008 | 05:43 PM
Ted B's Avatar
Possibly K1 crank and rods as well. That would definitely be a bit less pricey than Carillo and a $3300 domestically-made (I presume) billet crank. Is the difference worth it? That is a consumer decision.
Ok, but that was 25 years ago, done by a different (UK) group, and the company has changed ownership since that time. Asking no questions leaves only assumptions.
Much too expensive now, and rarely necessary. If I found myself contemplating something with a street car where steel rods will not suffice, I'd need to reevaluate my planning.
