Engine stuttered on hwy, then CEL.
Old Aug 19, 2008 | 06:26 PM
Vibrant's Avatar
I was doing about 80 on the highway on my way home from work, when the engine kinda stuttered and my check engine light came on. I get back in town and put it on the code reader which tells me its a p300- random/multiple misfire. I cleared the code, and the car hasn't done it again yet. Do you think it could be a coil since it says random/multiple? Spark plug? All I know is that any time I have diagnosed a bad plug, the reader always gave a specific cylinder number. I'm thinking coil. Thoughts?
Old Aug 19, 2008 | 06:29 PM
Billy@EnglishRacing's Avatar
When is the last time you changed your plugs?
Old Aug 19, 2008 | 06:32 PM
Vibrant's Avatar
Probably about 9-10k ago.
Old Aug 19, 2008 | 06:38 PM
FedEvo8's Avatar
Are you using the copper BPR7es'? If so, use should change them every oil change. Try gapping them to .022, should help...
Old Aug 19, 2008 | 06:40 PM
lightspeed1's Avatar
There is a TSB on that problem...it applies to all 8's ... check with Mitsubishi..
Old Aug 19, 2008 | 06:42 PM
Vibrant's Avatar
I am running Denso plugs right now. If I switch plugs/gap, will that affect my tune?
My mods are as follows: 3" BR TBE, Megan o2 housing, test pipe, K&N intake conversion, LICP, HKS 272 cams, Ferrea valvetrain, walbro 255, tune on 91.
Old Sep 17, 2008 | 01:34 PM
Vibrant's Avatar
I dont imagine that mitsu did a recall on this?
