can't boost over 28psi help help
Old Aug 22, 2008 | 12:24 PM
speedy evo's Avatar
Originally Posted by DBallz
Well its sounds like it's possible your BOV or your MBC.
my bov is a adjustable one so how should i adjust that softer or harder?
Old Aug 22, 2008 | 12:26 PM
MrEvo2nv's Avatar
harder
Old Aug 22, 2008 | 12:40 PM
speedy evo's Avatar
Originally Posted by MrEvo2nv
harder
so if i turn it harder i will hold more boost?
Old Aug 22, 2008 | 12:50 PM
rcheung's Avatar
If you turn it harder, the diaphram will just release faster and make a harder bov noise. It doesn't make the spring stronger.
Old Aug 22, 2008 | 12:59 PM
MrEvo2nv's Avatar
yes it does . it puts more preload on the spring so it will hold more boost. but your low end boost will suffer and you can get compressor surge.
Old Aug 22, 2008 | 01:17 PM
speedy evo's Avatar
i will try it tonight and see if it work.
Old Aug 22, 2008 | 01:55 PM
EVO8_PR's Avatar
I upgraded to dual springs
i did upgrade that already.
i did change that too the color is red it was blue b4
this statement indicates you swapped one color for another, what color and size combination do you currently have?
Old Aug 22, 2008 | 02:12 PM
speedy evo's Avatar
greddy 47mm wastegate and a red wastegate spring which is 1.5bar
Old Aug 22, 2008 | 08:06 PM
speedy evo's Avatar
i had turn the bov to the harder side but it still doing the something to me, so i had unplug the mbc from the wastegate the car actually feel a lot more better, it that ok to unplug the mbc from the wastegate? and i can hit 30psi with that unplug.
