tranny problem help....
Old Aug 23, 2008 | 08:32 AM
brandon1304's Avatar
you got it bud, great investment!
Old Aug 23, 2008 | 08:35 AM
OhsixIXBish's Avatar
Yeah now all i need to do is find a shop that wants to take it out and put it back in and have my car on there lift for the time its gonna take to ship it out and get it back...
Old Aug 23, 2008 | 08:38 AM
number 8's Avatar
It could just be the clutch. I lost 4th and 5th gear not to long ago, and thats what it turned out to be.
Old Aug 23, 2008 | 08:54 AM
U think so? idk just seems like all of the gears would not engauge if it were the clutch. ya know where im comin from? but if it happened to u i guess its possible. and really that would probally explain the griding goin into the other gears...am i right or wrong?
Old Aug 23, 2008 | 10:23 AM
number 8's Avatar
It didn't make sense to me, either. I didn't notice the clutch slipping under load in 4th or 5th gear. I was getting grind between 4th and 5th though. Then I down shifted on the highway, from 5th gear, and no 4th. They pulled tranny and said the clutch was bad. Also, has a bent shifter fork. and no reverse gear. New clutch ,shifter fork, and reverse gear. All is well, except my bank account.
Old Aug 23, 2008 | 11:15 AM
lol so it the shift fork explains ur gears...and yeah well thats what im thinkin my clutch isnt engauging all the way and it bent the shift fork so i dont have a forth now..
Old Aug 24, 2008 | 06:19 PM
UPDATE!!!!!! i took the car out for a ride last night. it sat all day yesterday i got off work got in it and went for a ride! the 4th gear was back? it drove normal. i started to drive it a little harder and the gear went back out? I was told by a buddy of mine to get it in 3rd gear and pull it back into 4th without using the clutch, so i did and it stayed engaged in 3rd. he told me it was my shifter linkage that was messed up? Dose this sound right? If it dose the dealer should fix this under warranty no matter what!
Old Aug 25, 2008 | 08:08 AM
Anyone??
Old Aug 25, 2008 | 08:18 AM
evo8nfs's Avatar
trying playing with your linkage.... check your clutch engagement.... make sure its engaging and disengaging properly... maybe a simple clutch adjust..... Always check the little things before you think it somthing major..... Also have you tried goin through gears with the car parked and the clutch in???? see if the problem still occurs.... Goodluck
Old Aug 25, 2008 | 12:38 PM
I adjusted my clutch out about 2 weeks ago and it was fine and driving fine and everything was good this happened outta no where. but ill try to do some of these things u recomended thanks!
Old Aug 25, 2008 | 12:54 PM
evo8nfs's Avatar
are you stock clutch?
Old Aug 25, 2008 | 04:45 PM
Yeah stock clutch..i bought the car with 14k on it stock and i blew the stock clutch bought an e.bay 6 puck clutch kit and a prolite flywheel and got it put in and the ring gear on the flywheel and chewed my starter and flywheel up. i sent it back to where i got the clutch put in, at the dealership where i purchased the car and said they couldnt do anything for me because it was an aftermarket clutch!! so i was mad at myself for doing such a foolish thing i just told them to put a stock clutch and flywheel back in the car...but to answer our question yes stock clutch with about 11k on it.
Khalid
Dec 26, 2018 01:18 AM
Fast-Mover
15
Apr 21, 2014 07:08 PM
DanDan1320
Jan 28, 2013 10:59 AM
pb91
Jun 8, 2011 02:44 PM
EvoIXMRT
11
Oct 31, 2007 05:10 AM
