Drivetrain Problems...
Old Aug 25, 2008 | 02:50 AM
ineedparts's Avatar
How many clicks...
Does anyone here know how many turns you have th turn the "push rod"
in order to adjust the clutch pedal on the act clutches....
and i was told my a reputable shop that... short shifters are a waste of money, and performance. ( its hard to get into gears with a short shifter) i am running the b&m short shifter.....
Thanks for the Help Guys...
Old Aug 25, 2008 | 02:51 AM
ineedparts's Avatar
bump for some good info anyone plz...
Old Aug 25, 2008 | 03:00 AM
ineedparts's Avatar
bump it up guys plz!!!
Old Aug 25, 2008 | 03:02 AM
ineedparts's Avatar
bump
Old Aug 25, 2008 | 03:36 AM
Ev0cRaZy's Avatar
Adjust your clutch. Gaurentee thats most of your problem
Most people complain about ACT Clutch Lockout, but only because they dont usually have it adjusted correctly
Old Aug 25, 2008 | 03:48 AM
Mitsutech56's Avatar
Check clutch adjustment first. I'd bet the 2 & 4 synchros are worn. Clutch lockout is not usually in just select gears.
ineedparts's Avatar
Thank you for the feedback... how do i actually adjust it? any how to? or starting point for me to do it? thanks again
Old Aug 25, 2008 | 04:03 AM
sikrsix's Avatar
Here ya go...
http://evomoto.com/tech_info.php?tec...bb79fbabcd26cc
Old Aug 25, 2008 | 04:21 AM
ineedparts's Avatar
Originally Posted by sikrsix
damn homie.... thank you so much bro!!!!
Old Aug 25, 2008 | 08:42 AM
Ev0cRaZy's Avatar
Let us know, if you havent ever adjusted it, I can about bet you thats the problem
Old Aug 25, 2008 | 09:59 AM
92gsxbaltimore's Avatar
also something to check... Your Shift linkage cable that controls the forward/backward movement might need the mounting plate adjusted or bent a bit.
Old Aug 25, 2008 | 01:58 PM
ineedparts's Avatar
i sure will, i am going to do it today!! i will keep you guys posted thanks bro
Old Aug 26, 2008 | 04:47 AM
ineedparts's Avatar
bump it up plz
Old Aug 26, 2008 | 04:49 AM
ineedparts's Avatar
bump it up....
Old Aug 26, 2008 | 04:59 AM
ineedparts's Avatar
bump
