Engine pull thread or write up?
Old Aug 25, 2008 | 04:18 PM
jmtx86's Avatar
Im pulling the motor and trany out of my evo VIII, this is my first time pulling a motor/trany out of an evo but not my first motor pull. I just want everything to go smooth and find out if I need any specialty tools prior to the pull so I don't get stuck.
Ive searched but came up empty https://www.evolutionm.net/forums/se...archid=9261589
If someone could give me a link for write up or alldata (that would be great!) id appreciate it.
-John
Old Aug 25, 2008 | 05:51 PM
dryad001's Avatar
Your going to have a loss of knuckle skin during the process. If you need any help let me know. I just pulled the engine/tranny from the top which I think is a pretty easy way to do it.
Old Aug 25, 2008 | 05:58 PM
cssaddictm4's Avatar
Will you have access to air tools or a portable impact?
Old Aug 25, 2008 | 06:31 PM
jmtx86's Avatar
That i don't mind, thanx for the offer ill def be taking you up on it. Im assuming you took the trany and motor out in one shot and left the TC in?
OR should I pull the trany and then the motor?
Na me and my boys are what you'd call drive way builder, maybe ill splurge on a compressor and some air tools or a portable impact.
full sti swap, this was done in the winter (it sucked)
Old Aug 25, 2008 | 06:34 PM
EvoVIII :D's Avatar
I put my evo on a lift and just dropped everything out from the bottom, super easy.
Old Aug 25, 2008 | 07:21 PM
Well I think the easiest way is:
Remove axle(s), have fun with the ball joints, and axle nuts. I would remove both axles so you can move the TC aside and not have to fight with it, although you can get away with not removing the passenger side one
Unbolt DP, and remove turbo and manifold
Remove rad for safety and room
Remove most top accessories, battery, intake piping, etc.
Disconnect complete wiring harness and move to drivers side of car (wrap in towel)
Disconnect AC and PS and move aside
Disconnect clutch lines from bell housing
Unbolt Transfer case (6 bolts) and separate
Remove engine mount bolts, and complete transmission mount.
Out she comes!
Notes: The TC bolts are probably the most difficult, especially with the intake on. The axle nut is (I think) 32mm and easily removed with a portable impact. My axles were a PITA to get out from the trans/tc. Everything else was painless.
Good luck
Old Aug 25, 2008 | 07:35 PM
jmtx86's Avatar
Out she comes!
Good luck
Sounds good, I already got most of it done, the harness, rad, turbo mani , ps, ac is all out so I guess ill get a hold of a hoist next weekend and do work (going away this weekend).
Thank you
-John
Old Aug 25, 2008 | 07:52 PM
Oh, and I am pretty sure you need a slide hammer to remove the shaft out of the transmission that goes through to the TC. Other wise you cant separate the TC.
Good luck
Old Aug 26, 2008 | 07:14 AM
KevinD's Avatar
the ball joints don't ever have to be seperated. the axles can come out of the hubs no problem with the strut disconnected from the hub... those two bolts are very easy to remove.
