Labor hrs for Head studs, Cams, & Spring/Retainer Install
Old Aug 27, 2008 | 08:04 PM
mchristian's Avatar
Question Labor hrs for Head studs, Cams, & Spring/Retainer Install
Wondering if anyone has a estimate on the time it takes or labor expense (what did you get charged) for installing new head studs, cams, and valve springs and retainers...on an Evo 9.
I have been reading up on this and there are several different ways to approach the install...some folks just remove the head, some leave it on, etc...so I assume there could be some variance in what different shops would charge.
If you've had Studs, Cams, and the VT upgraded or if you are a mechanic and have experence here please chime in!
Thanks!
Matt
Old Aug 27, 2008 | 08:31 PM
Craig King's Avatar
I'm interested in this as well.. although I'm more interested in installing them myself!
Old Aug 27, 2008 | 08:36 PM
Dapper Dan's Avatar
I would guess that most evo shops would charge around 5+ hours of labor on that depending where you go.... but it only takes about 3 hours to do.
joehoo's Avatar
a local shop quoted me 620 for cams install headstud install and a tune. pm for more info(va)
Old Aug 27, 2008 | 08:50 PM
mchristian's Avatar
Thanks for the info Dan, by the way I'm from NWF - Milton, FL!!
Old Aug 27, 2008 | 09:02 PM
Dogboxracing's Avatar
It takes more then 3hrs to do cams, springs retainers, and head studs. Unless your using a hammer and chisel.
Back on topic. We do lots of these packages. We like to leave the head on the car as not to disturb the head gasket. We like to take our time and call it a full days work. Can it be done faster yes. But when a hammer falls on a fender it makes for unhappy customers. We charge 475 for this job.
Black_EVO_MR
May 13, 2014 01:55 PM
evane
22
May 16, 2010 05:20 AM
SJ EVO 8
Automotosports - Illinois
Aug 16, 2005 01:59 PM
bolsen
Mar 24, 2005 12:20 AM
BSREVOLUTION
30
Feb 23, 2005 10:46 PM
