4G64 w/ MIVEC Head, What head gasket?
Old Aug 28, 2008 | 05:18 PM
SeanC's Avatar
What head gasket should be used for this combination? I know everyone has done the EVO8 swap, but I can't confirm which head gasket will work for the EVO9Mivec head. I called today and Cometic claims they don't have an EVO 9 head gasket. I can't use off-the-shelf or factory gasket because I have an 87mm bore.
Any suggestions from someone who has this setup currently?
Old Aug 28, 2008 | 05:19 PM
apagan01's Avatar
OEM brother...
Old Aug 28, 2008 | 07:24 PM
LT1runner's Avatar
4G63 head gasket that's 0.050s thick, with whatever bore size you're going with. I did a 4G64 block with 4G63 head as well. Cometic is your friend.
Old Aug 28, 2008 | 08:19 PM
SeanC's Avatar
Please read my original post.
-The OEM gasket won't work because I have an 87mm bore
-Cometic says they don't have an EVO 9 head gasket (that's why I called)
Anyone else know?
Old Aug 28, 2008 | 08:45 PM
LT1runner's Avatar
Anyone else know?
See above post. I went with a cometic headgasket. I went with a 4G63 headgasket pattern with the bore of a 4G64 (87mm) at 0.050 thinkness. You can do this too.
Old Aug 28, 2008 | 10:08 PM
Aby@MIL.SPEC's Avatar
you already have a used evo 9 gasket...if you pulled your head off your short block, locate a used 8 gasket = works on 4g64 conversions, lay the 2 on top of each other, see whats different & modify accordingly....could be more than a oil passage hole or 2.
i think cometic are the only 87mm bore gasket avaialable....
good luck...
Old Aug 28, 2008 | 11:45 PM
krayzeviet's Avatar
i got mine from slowboyracing
Old Aug 28, 2008 | 11:50 PM
mr.alex's Avatar
Works great in my 2.6L
Got mine from ExtremePSI
See now that you have the mivec head... is there really a difference in the headgaskets?
Old Aug 29, 2008 | 12:09 AM
Erik@MIL.SPEC's Avatar
I have read some people having issues with the Cometic gaskets. What would be the reason for that?
Old Aug 29, 2008 | 12:23 AM
vboy425's Avatar
you need cometic 87mm. don't keep using the stock size, head will eventually lift. Seen it happens in person.
asu11
Jul 26, 2021 04:24 PM
nomnom
May 30, 2017 05:58 PM
eus_evo8MR
Feb 13, 2013 10:20 AM
konstantinosIX
Feb 10, 2011 07:34 AM
moevo9
21
Mar 15, 2010 10:58 AM
