Oil leak around upper timing cover
Old Feb 8, 2017 | 08:18 PM
asu11's Avatar
I can't seem to pinpoint exactly where this leak is coming from. I have a clear upper timing cover so there's a light mist of oil on the inside of it after I clean it off and drive around.
Seems to be more on the intake cam side. (Evo9 so has the mivec gear)
I also see its fairly wet at the top left of the lower timing cover and also the top left of the upper cover. I took the lower cover off and everything in the timing area looked clean except some oil at the very bottom which is probably from the up top leak over time.
Things I have done already:
Changed both cam seals
RTV on valve cover
Thread sealer on motor mount bolt that goes into oil galley
Thread sealer on hydraulic tensioner bolts
New oring and bolt for mivec gear
Ideas I have that it could be:
Leak from head gasket area?
Mivec gear?
Any ideas?
Old Jul 26, 2021 | 12:33 AM
SeenBean's Avatar
RTV on valve cover
Mivec gear?
Any ideas?
what was the outcome of this ?
I have the same issue. I have a clear cam gear cover and this gets a fine mist of oil sprayed on it on the mivec cam gear side. Losing very small amounts of oil on each drive. Enough to cause a few drops of oil on the floor. Oil seems to run from the Mivec gear area all the way down the side of the block and then soaks everything in oil. Head Gasket replaced not long ago. Cam seals replaced not long ago. Value cover gasket new with dabs on corners. Occurs with both factory ventilation and catch can setup. Cant see any cracks on the value cover. The timing belt doesn't appear to get wet with oil.
Old Jul 26, 2021 | 01:04 PM
mazdabish's Avatar
Gasket on MIVEC gear might be bad if it's misting (implies it's getting flung around very fast) on the cam gear cover. Not a replaceable gasket as far as I know and your fix might be a new cam gear. If it was the cam seals I think they would be wet/seeping.
Old Jul 26, 2021 | 04:24 PM
hutch959's Avatar
if its spraying.. its got pressure on it... coming from the cam gear.
either the cap seal or the cam gear itself.
fugiwara
Dec 13, 2015 12:19 AM
Brsox10288
Dec 16, 2010 06:24 AM
ohthree
Apr 30, 2007 08:07 PM
HiRevnVIII
21
Oct 12, 2006 06:32 AM
use2vtec
12
Apr 7, 2006 01:17 AM
