shifter bushings or under hood bushings?
Old Sep 3, 2008 | 06:42 PM
def1's Avatar
i can only afford one right away. which would be better to get first. or will they both help the same. Im getting a 3rd gear grind eveery so often and a high rpm lockout from1st to second occasionally. Eventually i will get both things and new engine mount bushings but for now which would be the best thing to get. Thanks
Old Sep 3, 2008 | 08:04 PM
def1's Avatar
anyb\ody?
Old Sep 3, 2008 | 08:53 PM
chaotichoax's Avatar
underhood without question
Old Sep 4, 2008 | 05:26 AM
Davo's Avatar
i bought as a backup to when mine goes
the stock ones are in very good shape
in real benefits to change out b4 they actually show any signs of wear
Old Sep 4, 2008 | 05:50 AM
JakeTheVIII's Avatar
Just save up until you have enough for both....The buschur racing underhoods are like $28ish....You'd probly spend half that on shipping them separately.
vboy425's Avatar
both. it's damn cheap anyway
Old Sep 4, 2008 | 05:54 AM
WagsEvo's Avatar
The underhood bushings are a great improvement - especially for only $30.
How much are the in-car bushings? Aren't they only about $30 as well? No offense, but if you can't afford a $30 set of bushings, how are you going to pay for your next oil change, tires or brake pads? Good luck on whatever you choose.
Old Sep 4, 2008 | 06:00 AM
Chemwarrior's Avatar
The underhood bushings will provide the biggest positive change. They are a night and day difference compared to the mushy OEM ones. Just ensure you lube your bushings during the install.
Old Sep 4, 2008 | 06:46 AM
Davo's Avatar
i guess i will be installing my works pieces this weekend then
Old Sep 4, 2008 | 06:54 AM
juanmedina's Avatar
:d ..........
Old Sep 5, 2008 | 10:05 PM
def1's Avatar
ha i can afford both. but im saving up for new clutch, cams, tune, wideband, and timing belt. I just wanted a quick solution for my 3rd gear grind before i have to save up for a new tranny too haha.
Old Sep 6, 2008 | 12:43 AM
wshihdnevo's Avatar
Old Sep 6, 2008 | 12:45 AM
wshihdnevo's Avatar
I know this is a double post, but I think if you bought a front lower motor mount it will 100% help alot better than the underhood bushings will. I am speaking from experience, take my word for it. The one I recommend is the Blox one, which I guess I am biased too, b/c of the price, but its a great product and was the most noticeable difference out of all of my bushings I have installed so far.
Old Sep 6, 2008 | 05:57 AM
Evolessfornow's Avatar
I bought underhood bushings and the Blox roll stopper. Grinding better be a thing of the past after I put those on. Lol.
Old Sep 7, 2008 | 03:53 PM
Installed Kartboy under hood bushings today. Shifter feels nice.
