View Poll Results: I would like to see how many people have this problem, please vote.
Yes, I have it too.
138
75.41%
No, mine has no problem.
45
24.59%
Voters: 183. You may not vote on this poll
Do your clutch chatters in the morning?
Old Oct 24, 2003 | 09:48 AM
webguy330i's Avatar
Originally posted by heshamnaim
hey is talking about the TOB chatter not the car stuttering when you don't give it enough gas....and it isn't a big deal anyway...either of them for that matter
No he's talking about the clutch engagement shudder, the clutch disc is very grabby when it is cold. TOB noise and car stutter are two different topics from this.
Old Oct 24, 2003 | 09:58 AM
sevensign's Avatar
I have that clutch chatter thing even when the car is warmed up, it occurs while i'm letting go off the throttle pedal slighty in cruising in 2nd or 3rd gear....but whenever i push the clutch the chatter gone....sumthing is like trying to engage or sumthin...a lil while its a bit annoying though....i dont have dat chatter on my other car...the clutch feels solid
Old Oct 24, 2003 | 10:17 AM
M3lachsilber's Avatar
choad
Have it too..
Totally normal..
Old Oct 24, 2003 | 10:21 AM
webguy330i's Avatar
FWIW I had the same "issue" with my 330, as did a TON of others. It's a physics thing ya'll.
Old Oct 24, 2003 | 04:42 PM
Evo spooling's Avatar
I have it too. I noticed it when the weather turned cool. I am also real light on the gas so not to wake up the neighbors at 5am. This may add a little to the shudder or chatter.
Old Oct 25, 2003 | 08:19 PM
MaxR's Avatar
no clutch chatter for me but mine was built in august so maybe they finally fixed that problem.
Old Apr 12, 2004 | 07:51 AM
MrBonus's Avatar
Mine does but I've never worried about it.
Old Apr 13, 2004 | 07:21 AM
EvoT's Avatar
I have that problem too. Does it every morning 9,000 miles
Old May 18, 2004 | 11:54 PM
ill born's Avatar
My clutch chatters no matter of the temp. HKS gdmax. dont worry i didnt vote
Old Jun 29, 2004 | 12:50 PM
HMFQ-300's Avatar
I have this chatter every morning, especially when its cold. The chatter goes away within 30 min. You can rev. the car a little more (2k) before you release the clutch - this helps.
I've had it since day one, my car now has 6k miles - everything is fine.
Old Jun 30, 2004 | 09:13 AM
whitet777's Avatar
Mine started to shudder, sometimes violently, around 3000 miles. Now that I am aware of it, I can help the cause by giving it a little more gas and slipping the clutch. After about 2 to 3 stop and starts, the clutch is fine.
Old Oct 1, 2004 | 01:30 PM
thedeatons's Avatar
I have 82,000 miles on my OZ and it has been doing it forever, but got worse it seems at around 60k or so, because now it even does it some after warm up.... this may be normal with these cars/clutches, but it is not normal relative to the rest of the automobile world, as I have NEVER had a car or motorcycle that shudders like this before, cold or warm, and I've had quite a few of both.... I can't imagine Mitsubishi selling many of these cars of they behaved this way during the initial test drive, which makes me think they have somehow band-aided this problem so it doesn't appear for a while through the use of oils or some type of friction modifier.... This is the only thing I hate about the car... By the way, i'm running Red Line synthetic transmision fluid (gear oil) in my car since 37k, and it was doing it before that swap also... James
Old Oct 1, 2004 | 01:35 PM
Guack007's Avatar
mine just started doing it a few hundred miles ago (Im around 8k now) if its cold it is pretty hard to engage the clutch smoothly. I think its a combo of the TOB and discs not grabbing well. kinda anoying but its normal since this is a mitsu and not a porsche
Old Oct 1, 2004 | 01:44 PM
Ty-Evo8's Avatar
Yup, I get the chatters as well. Mostly it happens in the morning. Like everyone has mentioned before...once the car has warmed up it goes away.
Now that the weather is getting much colder (I am from new england) I have noticed that it happens a bit more often during the day when the car has been sitting awhile and has cooled down again.
No big woop...I have the stock clutch and no problems yet. I have 15,000 miles on her.
Old Oct 1, 2004 | 02:01 PM
SilverEvo8owner's Avatar
It's normal for a standard cold car. Mine does it. Stock clutch, 40,000 miles to date. No sign of slipping or anything, just an occasional chatter. Completely normal.
For the record, my brother's STi does it a lot as well.
