What is the best set up for FPGreen ???
Old Sep 10, 2008 | 06:01 AM
  #46
mike1023's Avatar
Originally Posted by mike1023
i can say we have been trying all diff kinds of things with my car. We had put on one of the first greens to be out and this green has been on about 4 other cars before mine LOL. and it made 397hp at 20psi boost. was on 93 oct was a very safe easy turn.
opes sorry guys i miss lead the info. my friend told me that that was the stock evo9 turbo. i have to find out how much the green made at low boost on 93oct.
Old Sep 10, 2008 | 06:14 AM
  #47
zedevo's Avatar
tHX A LOT GUYS ... so its better to stay on stock ECU ...
Old Sep 10, 2008 | 10:23 AM
  #48
LoKiEvo's Avatar
Stock ECU works amazing for the EVOs however you can make more power with the standalone. With that said though I would not use any other standalone other than AEM... its proven to be the best for the EVO. So unless you are gonna go AEM I would just suggest staying with the stock ECU. So many people like AL or Mellon have those things on point, you can just send it in to them with a modlist and get a near perfect tune.
Old Sep 10, 2008 | 10:26 AM
  #49
diiirk@AwdMotorsports's Avatar
stick with stock ecu, and after all the bolt ons, go with e85 for the most power
Old Sep 10, 2008 | 11:07 AM
  #50
zedevo's Avatar
OMG ... ok so ill stick on OEM ECU ...
no more MOTEC ...
Old Sep 10, 2008 | 06:20 PM
  #51
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
no more MOTEC ...
What part of the globe are you in where you can't get AEM and a tuner to map it?
Old Sep 11, 2008 | 04:06 AM
  #52
zedevo's Avatar
ok , 1st of all We don't have it here , i have to buy it from US,
2nd : no one know about the softwar of AEM so its really deficult to have AEM, I SOLD my 350Z cause i bought a UTEK and no one know how to work on it ...
My dear in our country they use MOTEC , ECUTEK only ,
Old Sep 11, 2008 | 05:50 AM
  #53
DBallz's Avatar
Ok then ECUTEK it is.
Old Sep 12, 2008 | 03:48 AM
  #54
zedevo's Avatar
mmm but im so excited to have MOTEC WITH anti-lag to awaik all the street,,, lololol im jocking ... from time to time i track my car so it will be GR8 if i switch the anti-lag IT WILL HELP U TOO MUCH when ur going into the corner as like u finish the corner ...
BUT ITS RISKY to my turbo to have an anti-lag ... SO IM AFFRAID !!!
xxx
Old Sep 15, 2008 | 02:46 PM
  #55
zedevo's Avatar
There is an anti-lag on ECUTEK ???
Old Sep 15, 2008 | 02:58 PM
  #56
konstantinosIX's Avatar
Ecutek has a soft-mild antilag.
If you want a real ALS you have to go with Motec.
Motec can handle the ALS also with a button,Ecutek can't.
Old Sep 15, 2008 | 03:16 PM
  #57
zedevo's Avatar
What do u think MOTEC can do on MY setup ??? better than ECUTEK ???
Old Sep 15, 2008 | 08:18 PM
  #58
I had Ecutek before I have Motec now,
Motec is more throttle responsive.
It'll perform better cause you will get the MAF out.
MAF is an air restriction in front of compressor.
You can tune your car in less time than Ecutek.
Old Sep 18, 2008 | 11:13 AM
  #59
zedevo's Avatar
and what is the diff between Aquamist HFS-1 and HFS-5 ?
Old Sep 18, 2008 | 12:12 PM
  #60
mike1023's Avatar
me personal do not like the idea of aquamist. if want power just run race gas. why have to warry about high boost with adding another mix. when if the pump or something fails say bye bye to something in motor.
