am i crazy or is my gauge broken
Old Sep 10, 2008 | 09:04 PM
fox2boost's Avatar
whats up guys,
ever since i bought my car my oil psi gauge has been a little weird its like the gauge has a mind of its own
When it first started reading low i posted and someone said that the low readings were due to the mounting position of the sender. I was OK with this and it was always consistently low so i have been dealing with it. Lately it seems like its always at zero and just barely goes up to twenty or so when you boost it. The car runs awesome i would definitely know if something felt wrong or it was really 0 psi.When its cold and thew oil is thicker the gauge reads high as it should. The stock oil light has never come on so i know the gauge is just reading low.
The question i have is can i buy the kit to put the pickup near the oil filter because right now the gauge is about as use less as *i*s on a bull. Any info or links would be awesome im very **** about my car and this is really starting to bother me
Old Sep 11, 2008 | 09:31 AM
Prosport Gauges's Avatar
where is the sender located now ?
When was the last time you changed your oil?
How long have you had the gauge/sender installed?
what brand are they?
Old Sep 11, 2008 | 09:43 AM
Daryl Nilsen's Avatar
Yea what type of gauge is it? My prosport oil pressure gauge worked for like two days and now it just stays around 20 psi at all times and never moves, it jitters back and forth about half a psi even when the car is not started, iv tried everything to fix it and gave up, it had been this way for about a year now. My other prosport gauges work fine though.
Old Sep 11, 2008 | 10:02 AM
Davo's Avatar
my stri sender went kaputs after 2k km
ordered another, hopefully won't do the same
i used the 42 draft design fitting by the oil filter housing
Old Sep 11, 2008 | 10:08 AM
Marshall O's Avatar
This is what I have:
http://www.amsperformance.com/store/...oducts_id=1201
Run this line to the oil filter housing. I mounted the sender on the firewall to reduce vibratios. Reads very high on startup, 10-20PSI @ warm idle.
Old Sep 11, 2008 | 10:11 AM
MyEvoDream's Avatar
+1, this line works great, no leaks and reads great
Old Sep 11, 2008 | 10:22 AM
Knguyen228's Avatar
I have the Defi BF gauge and the greddy oil block adapter. works really well. I have about 15,000 miles on the sender now and have no problems with it at all. start up at 20psi and idle at 8-10psi. WOT at 110+psi.
Old Sep 11, 2008 | 10:36 AM
tommyevo's Avatar
I had a problem with my pro sport too. It always read kind of high, at idle it would be 20 psi but when i would get on the gas a little it would bury it to 100. Now it just sits at 100 psi all the time, called pro sport, they said they would replace it so i sent it back today.The guy that helped me was Glenn. All my other pro sport gauges work great.
Old Sep 12, 2008 | 01:04 PM
lol.. what happened to fox2boost and his problem ?? no response?
Don't mean to hijack the thread but..
Prosport:- Anyone can contact us direct if they need any tech advise or experiencing a problem. We are easy to get in touch with and we stand behind all of our products.
Old Sep 12, 2008 | 08:47 PM
fox2boost's Avatar
sorry guys been wicked busy lately, i change my oil religiously every 2500-3000. before you bash me about not stretching it longer because its mobil 1, i know i could go 5000 but im old school. the gauges are auto meter nexxus and i have no idea were the sender is because it was already installed before i got the car....im guessing the head????????
Old Sep 12, 2008 | 09:01 PM
EVO8emUp's Avatar
First of all, don't listen to retards on here that tell you to run your oil to 5000mi. before changing.
Old Sep 13, 2008 | 04:33 AM
ok, you are going to have to find the sender. Start at the gauge and trace the wires back to the sender. You may have a broken wire, loose ground, chaffed wire-causing a short, etc..
If all those things are ok then it is the sender itself. you can buy a replacement for autometer senders.
