Evo Red
Old Sep 11, 2008 | 05:34 AM
sarge uk's Avatar
Smile Evo Red
Hi Guys
It is dificult to get an idea of what sort of power these turbo's will make.
Our RR figuars in the uk are Fly wheel and we use 99 RON fuel etc
If a FP green make approx 470 bhp @ the fly what do you think the Red will make?
Regards
Old Sep 11, 2008 | 05:46 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I think Rob from Forced Performance made 470 on 100oct. Do a search on the Red turbo and you can get your ideas from that.
Old Sep 11, 2008 | 05:53 AM
sarge uk's Avatar
Hi
I have read all the posts but they are all in WHP not Fly HP.
Thanks Anyway
Anymore?
Old Sep 11, 2008 | 05:55 AM
TeStUdO's Avatar
Originally Posted by sarge uk
Hi
Thanks Anyway
Anymore?
Add 15 to 20% to the WHP for flywheel hp.
Old Sep 11, 2008 | 06:10 AM
sparky's Avatar
U.S. 93 0ctane(Research+Motor/2)pump gasoline is equivalent to 98 octane R.O.N. gasoline. Guys over here are trading in their Greens like hotcakes and moving up to the FP Red in droves. My guess is that depending on the tune, you could see a 35-55 BHP increase if going from the Green to the Red. There are several threads comparing the Red's power numbers to those of the Green. Just extrapolate from the AWHP #'s using TeSTudo's rough conversion factor(+15%). Of course, you have to take the calculations with a grain of salt as you'll be comparing figures from a rolling road that spits out brake horespower to any number of different dynamometers each calibrated differently.
Old Sep 11, 2008 | 07:57 AM
Shacochis06's Avatar
379@313 with basic bolt ons stock ic 93 oct...on a low reading mustang dynp
Old Sep 11, 2008 | 08:07 AM
GrocMax's Avatar
peak Flywheel HP = 10HP per lb/min airflow (gasoline, avg. setup), can get up to 12 HP per lb/min on alternate fuels and optimized setups.
So...... Green we advertise at 49 lb/min, Red we advertise at 58 lb/min.
Old Sep 11, 2008 | 09:16 AM
EE's Avatar
EE
If you are asking abt a car that can make 470 bhp with a green, then i suppose it has full bolt ons. In this case you should easily see over 500 flywheel with the red.
Make a little research over here and see what the reds are making.
From my personal experience, different dynos over here read as follows:
Dyno Dynamics: add abt 20% to get flywheel bhp
low reading mustand (like the one at CBRD and Buschur): add abt 15%
Dynojet & high reading mustang: add abt 8%
Good Luck
Old Sep 11, 2008 | 12:18 PM
DimitrisIX's Avatar
Actually I have seen dynos of UK cars that had 490 on a Green and high boost/bolt ons. I guess the red will easily make 520-530 on a IX with built motor/ full bolt ons and shell 100 RON fuel (at least 2 bar boost ofcourse). I guess we will know for sure in a few months time. I will be running a Red converted to ball bearing from a company in the UK.
Old Sep 12, 2008 | 02:31 PM
sarge uk's Avatar
Thanks for the replies guys.
Here is a link to my car info,what do you think it will make on mine?
http://www.lancerregister.com/reg_ca....php?carid=948
Regards
Old Sep 12, 2008 | 02:33 PM
EVOslow's Avatar
one guy made 470awhp on 100octane at 26psi with supporting mods. thats pretty rediclous if u ask me lol.
Old Sep 13, 2008 | 01:19 AM
sarge uk's Avatar
So all thing being equal,if the green flow 49lbs which equates to 490 fly bhp ,(which is achievable) then it should be possible to make 580 fly bhp on a Red ?
Possible?
Regards Andrew
QUOTE=GrocMax;6104834]peak Flywheel HP = 10HP per lb/min airflow (gasoline, avg. setup), can get up to 12 HP per lb/min on alternate fuels and optimized setups.
So...... Green we advertise at 49 lb/min, Red we advertise at 58 lb/min.[/QUOTE]
Old Sep 13, 2008 | 08:42 AM
SWOLN's Avatar
In Puerto Rico, I believe 600 wheel hp has already been achieved.
https://www.evolutionm.net/forums/sh...hlight=600+RED
Old Sep 14, 2008 | 01:18 AM
DimitrisIX's Avatar
The stock IX turbo has 41 lb/min and equates 410-420 bhp on a IX with cams. Perhaps 550 bhp on a Red is a realistic estimate.
Possible?
Regards Andrew
[/QUOTE]
Old Oct 8, 2008 | 12:53 PM
GrocMax's Avatar
Stock 9 turbo is ~44 lb/min.
