greddy profec b problem
Old Sep 16, 2008 | 03:11 AM
yikez's Avatar
I have a problem with setting my ebc to 25psi.
Mods: full boltons + evo green + gsc s1's
Prior to evo green: I used to have my SET at 66% to reach 22psi.
Post evo green: to reach 22psi it hasnt changed still at SET 66%. However, now to boost 25psi i have my SET at 93% just to reach 25psi.
i feel there is something wrong, i have checked for boost leaks and there is nothing. car drives normal and pulls very hard all the way to redline. idle is perfect.
I feel there is something wrong because this means i will never be able to use my greddy EBC for high boosts e.g. 28-32psi for meth or race gas. Whats the max boost limit on the greddy ebc? I feel the max i can get out of my EBC is 26psi because im already at SET 93% ... i had to increase SET almost 30% to go from 22 to 25 psi..
thoughts ...
Old Sep 16, 2008 | 04:37 AM
1NastyMR's Avatar
you have a problem there buddy my 93% is about 36lbs gain 5% setgain 221 limiter disabled warning 320= 32lbs
Might have a problem with your wastegate and its not adjusting properly when your turning your % up
Old Sep 16, 2008 | 04:45 AM
aka.ralliart15's Avatar
I have the same problem but at 24 psi, what kid of BOV you got?
The BOV might be leaking at that point.
Anyone else have advice?
Old Sep 16, 2008 | 10:09 AM
yikez's Avatar
i've got the stock plastic DV ..
i did not purchase the green 18psi wastegate as it was recommended by my vendor only for 27psi and above..
should i purchase the jdm metal DV and 18psi actuator?
Old Sep 17, 2008 | 11:18 PM
yikez's Avatar
bump ..
anyone else have the same problem?
Old Sep 18, 2008 | 01:48 AM
Toxin's Avatar
There is your problem I guess...
The stock (plastic) bov won't hold much over 23-24 psi.
Old Sep 18, 2008 | 04:26 AM
yikez's Avatar
Do you mean that because the plastic BOV is not holding boost .. thats why my SET is as high as 93% ?
Old Sep 18, 2008 | 10:04 AM
yikez's Avatar
bump for more ideas...
Old Sep 18, 2008 | 10:17 AM
bluebanana23's Avatar
All IX's came with metal DV's with hold up to 25 psi. Looks like it's time to upgrade anyhow.
Old Sep 18, 2008 | 02:25 PM
yikez's Avatar
Metal? You mean plastic don't u?
What I know is that only JDM ix's came with metal dv's. Also, euro spec evo's come with plastic dv
Old Sep 18, 2008 | 06:56 PM
your best bet would be to upgrade your BOV thats what I'm doing next week.
Old Sep 18, 2008 | 07:01 PM
kreionic's Avatar
usdm evo IX have the same dv. Its the metal one. 03-05 usdm have the plastic
Old Sep 18, 2008 | 07:02 PM
4WS Tuning's Avatar
Sounds fine... Youre running most boost so youre going to have higher numbers.. That EBC is good for 30 pounds of boost...
The other set of numbers, I forget the name, the setting that ramps 5%-35% needs to be set higher to run more boost.
The ix bov will hold 26pounds usually, i've seen it hold much more on many cars. I personally ran 34psi and never had a problem with it.
Cheers!
Old Oct 27, 2008 | 03:17 PM
yikez's Avatar
i've been doing some searching online .. and i think the plastic cap thats on the NC terminal is still on ... where is that located though . ? i have no idea.!
Old Oct 27, 2008 | 10:09 PM
yikez's Avatar
bump
