Installed ETS FMIC now some issues.
Old Sep 18, 2008 | 06:47 PM
Gordian79's Avatar
I installed an ets 4" IC kit with 2.5" piping along with an ets intake pipe.well i have a
couple of issues first is that car idles higher then before when cold(maybe its just
me).second issue is that car wants to stall at low speeds.like for example when
parallel parking. also where do i put the small hose that was on stock intake.hose
goes onto bcs i think.
Old Sep 18, 2008 | 06:50 PM
OhsixIXBish's Avatar
Need a tune? what other mods? Get a k&n filter or a small filter and attach it to the valve cover..
Old Sep 18, 2008 | 06:54 PM
Gordian79's Avatar
yea i think i need a tune.no other mods yet.but i have fuel pump,fuel regulator and 720 cc injectors.im waiting to put the fuel system before a tune.putting k n filter on valve cover would make a mess.the line im talking about is the skinny one that goes into stock intake pipe.
Craig King's Avatar
Both the higher idle and tendencies to stall can be from the same problem. Sounds like you didn't get something reconnected properly when you did the intake.
Old Sep 18, 2008 | 06:55 PM
cinek's Avatar
get a tune but you still will have some issues with the intake.
8UpUrV8's Avatar
boost leak? did you test after installing?
Old Sep 18, 2008 | 06:59 PM
Gordian79's Avatar
yep did a boost leak test its tighter then a virgins.....
ill double check intake make sure theres no there.the only hose thats disconnected is one that goes to boost solenoid.ill put that on and see what happens.
Old Sep 18, 2008 | 07:02 PM
Craig King's Avatar
That's why I'm still running the stock airbox.
Old Sep 18, 2008 | 07:50 PM
YogSaahoth's Avatar
Veteran: Army
like a few people have said, get tuned..aftermarket maf pipes tend to mess with idle a bit and have been known to cause stalling.
Old Sep 18, 2008 | 07:53 PM
Gordian79's Avatar
^^^^^that hose is connected.i just need to connect thin hose.
Old Sep 18, 2008 | 08:19 PM
Curt@MrLed's Avatar
Former Vendor
Intake tube causing issues. bov on backwards. get tune. they will find the issue.
Old Sep 18, 2008 | 08:26 PM
EvoFredo's Avatar
pics please
can you take some picks so we can see.
Old Sep 18, 2008 | 09:17 PM
mrfred's Avatar
The problems are from the intake pipe. Needs a tune.
Old Sep 19, 2008 | 07:24 AM
HighwayStarX's Avatar
I've been having the same issue however I am tuned. I am running the ETS 3" intercooler with lower and upper intercooler pipping, ETS Mass Air Intake System, Buschur Racing Inline Manual Boost Controller, and Stock BOV.
When Im cruising in 5th gear and my boost is at 0-5ish I get a fluttering and sometimes it feels like the car is being pushed backwards a little bit. I'm trying to figure out what is causing it but Im not to sure. Any ideas?
Old Sep 19, 2008 | 07:35 AM
redboosted05's Avatar
wat you are getting is compressor surge. What blow off valve are you running? you might want to loosen the spring up a little.
As for the OP I understand people have said they have been having problems but I had no tune with tht stuff for a week untill my appointment, granted I don't drive my car all that much. So I would look at your connections first then simply get tuned!
