Exedy triple cerametallic vs Exedy triple carbon
I will buy an Exedy triple disk clutch kit for my EVO 9 (6MT) and I wonder which one.
Cerametallic or carbon?
I would like to hear your opinions-suggestions.
I aim for 650-700 whp.
I will buy a 5 speed transmission later.
Now I need to find out this....
Which clutch has the bigger torque capacity???
Can I install a MM023HBMC Exedy triple carbon clutch w/o an installation problem???
Sorry to bring back a dead thread, but +1 as I am wondering the same...and if you guys didn't know shep has recently started building 6 speed trannys which have been tested. A few users on here have them. They replace gears 3,4, and 5 (the weak gears).
The built 6spds are still not as strong as the built 5spds, Shep himself has said this. Sure theyre stronger than stock, but for brute torque the 5spd is still the way to go.
Konstan,
You're forgetting some basic principles of the drivetrain. If you buy a clutch that can handle a very high torque capacity and your transmission is rated nowhere near that you are putting a brutal amount of stress on the drivetrain not just 4th gear. THe smart thing would be to swap to a 5speed and put a triple cerametallic in with the 5speed swap. Its pricy but its the correct way to go about it. Putting in a triple on a stock 6 speed is more expensive because you will
break the 6speed making it lose value for sale
lost the cost of labor to put in the clutch in the first place
pay the labor to take it out
potential damage to other components
do it one time and do it right; for now buy a clutch and transmission and put it in yo closet
True, I skimmed the thread a while back and from what I remember the shep 6 speed can handle 500-550 whp which is good for my goals, but what defines brute torque? When I'm done w/ my build I plan to be at 450-500wtq
FL_SilverEvo8
Nov 22, 2016 06:39 AM
evodrivesme
Oct 27, 2010 09:19 AM
DynoFlash
Jun 3, 2008 08:47 PM
carbon, cerametallic, cerametellic, clutch, disc, disk, evloutionm, evo, evolutionm, evom, exedy, hd, installation, kit, torque, triple
