Prosport oil pressure sender leeaks!?! HELP :-(
Old Sep 26, 2008 | 03:02 PM
lightspeed1's Avatar
Here's the deal.... I have the Prosport oil pressure guage and oil filter adapter (for tthe sending unit to connect to)..... Here's my problem, I have tightened, used thread sealant, and even pipe thread tape..... but the oil pressure adapter plate still leaks!?!?! I am curious what alternatives do I have? Is the thread pitch of the sending unit compatible with the factory Mitsu oil ports? Or will this gauge wire into the facory sending unit (and still be accurate)?
I am not looking to replace the gauge, or the sending unit...I just need to ditch the oil filter adapter plate, and find a more direct alternative...
Thanks again :-)
Old Sep 27, 2008 | 07:47 PM
bump....anyone?
Old Sep 28, 2008 | 06:11 PM
ttt
Old Sep 29, 2008 | 12:24 PM
tt
Old Sep 30, 2008 | 08:20 PM
sharkm87's Avatar
whats the adapter for, i have my sender directly in the oil filter housing
Old Sep 30, 2008 | 08:31 PM
jmelocik's Avatar
I have mine on a right angle adapter and a thread adapter. Both of which lose about a drop of oil in two months. Having had a few aircooled VW's in the past this is more than acceptable to me!
Josh
Old Oct 15, 2008 | 04:20 PM
VRSF Tiago's Avatar
Josh
Where exactly did you tap into the oil filter housing? I just bought one of these and wanna make sure I get the most accurate location.
Old Oct 16, 2008 | 12:35 AM
ThunderOZ's Avatar
my prosport sandwich adapter leaks as well, but it is very little oil...
Old Nov 10, 2008 | 11:37 AM
Neuspeed06's Avatar
My prosport adapter leaks too, and looks like it sprayed as well a couple times. Any solutions to this?
Old Nov 10, 2008 | 12:01 PM
Balrok's Avatar
http://store.42draftdesigns.com/CNC-...ducts_c_6.html
I used their adapters to go into the already built-in taps on the filter housing, have both the pressure and temp prosport gauges, i have 0 leaks and beat on her at the track several times a month.
Old Nov 10, 2008 | 12:03 PM
lancer2show's Avatar
no oil leaks at the adapter or sender for me
i just teflon taped it really well.
Old Nov 11, 2008 | 01:11 PM
randomevo's Avatar
anyone have pics of their setup?
Old Dec 11, 2008 | 05:00 PM
Neuspeed06's Avatar
I ended up just sending the adapter back, and got my money back. Ill buy the 42draftdesigns one instead.
Old Jan 23, 2010 | 07:22 PM
localtoys73's Avatar
was gonna pick one of these up
is this the one that leaks?
http://cgi.ebay.com/ebaymotors/Prosp...Q5fAccessories
golgo13
Jan 26, 2013 04:36 PM
4g63kid
Dec 16, 2012 08:36 AM
adriano_917
Mar 19, 2012 07:31 PM
taylorgang
Sep 18, 2011 10:28 AM
thedru13
Sep 29, 2009 09:39 AM
