AFI Twin Scroll 3076 Dyno part 1
So I was finally able to get my car on a Dyno this week to check out one of the first "prototype" AFI twin scroll 3076 kits.
First the mod list:
Stock heads, block, ECU
Stock intake cam, helix 272 exhaust cam
ebay intercooler,
U/LICP
60/40 Meth
Stock BOV and Turbo XS boost controller (i mention this for a reason)
And second the qualifiers:
These numbers are on a mustang dyno where a previous stock turbo BR stage 4ish evo8 with 264 cams and a mail in flash put down 282hp/292trq @22psi. Clearly a low reading dyno.
Now, the reason this is "part1" is because the dyno operator said i have a major leak at my BOV which is pretty much causing my turbo to spin itself crazy in order to run the 29ish psi I was aiming for. That being said, these peak numbers are way off from what we expected, but the graph will give a good idea as to the RESPONSIVENESS of the turbo. the turbo XS boost controller is also having issues handling the twin synapse wastegates, so that'll need to get changed shortly too.
And without further ado!
AFI Twin Scroll .78 3076 trying to hold 29psi on a stock block evo9 - Green is boost, Blue is wtq
Again, the peak numbers aren't really relevant right now, this is more to show the responsiveness! The Boost line (green) is clearly starts dropping off after 26psi which explains the torque and hp limits. But damn do they ramp up quickly! Full 29psi by 3800 with the leak, and 200ft/lbs at 3300 compared to 3000 for the stock turbo, both in 4th gear!
Here is the evo graph for comparison
Even with the leaky BOV, this kit is only giving up ~250-300 RPMS of spool over a stock turbo!
I have to thank Adam Hennessy for the hours of hard work he put into installing, troubleshooting, and putting an impressively safe street tune on the car given the crazy wg and bov setup! And also thanks to ESP for their dyno and additional troubleshooting efforts
I've had this kit on for about a month of street driving and I can honestly say it feels awesome on the street. Nearly instantaneous Boost in every gear, and noticeably more responsive compared to the atp kit that was on the car previously. I can't wait to switch out those two pieces and make some real power now!
First the mod list:
ebay intercooler,
U/LICP
60/40 Meth
get a new tuner.. wow
I cant read ur dyno run but i think i see 400 hp?
WITH METH?!?!?!?!
I put down 392 on a mystang with stock block/head/clutch.. ON PUMP in a hot room..
WITH METH?!?!?!?!
I think you missed the part about this graph isn't to show hp, just the responsiveness of the TS kit. The hp is WAY WAY low for what this kit can do because of the major boost leak. I don't think you made 392 with a giant boost leak on any dyno...but did you get peak trq at 3800?
Joe,
I did get your email tonight in regards to the runs. It was only time before the MR valve failed and started leaking. I'm surprised it didn't give out on the ATP setup. The Syncronic will take care of that issue for good and is an easy install. The finiky MBC was another ordeal we had discussed and I know you had mentioned the excessive cost of the AEM unit with the 3bar MAP update to run 30+lbs but it seems you're pushing to go that route eventually anyway..
You're correct that this thread will probably go down in flames here. If you have any other questions or comments my email is always open. Feel free to call me on the phone this upcoming week to discuss anything you'd like. I'll be open for updates to the car in the next couple weeks if you're looking to get something done before snow flies here
518-225-8384
Adam Hennessy
R247 Motorsports
518-225-8384
Adam Hennessy
R247 Motorsports
AND ur running meth!
A few things to note:
- The car has a factory intake cam and a mild exhaust cam. Get a good cam upgrade for this car, but nothing too wild. It WILL make a difference.
- The 'meth' is only 40% meth, and 60% H2O. You cannot compare that with others who are using 100% meth. I say forget the meth for now and tweak it on 93 octane first at ~28 psi. Show the dyno charts for that.
-The boost leak is not helping the situation. Get that fixed and do it again.
Moving on, we tried to turn the boost down to 25psi to avoid the leak and tune there, but the BC wouldn't cooperate, so it is what it is for now until a few parts come in.
Ted B, you're right on about the cams. Definitely leaving space to grow there, once these two issues get cleaned up. Probably the same is true with the IC down the road.
Considering all of that, i'm very happy with the way the kit is performing down low NOW and WILL BE performing up top once the two little issues get cleaned up and a second run is made.
There are other issues that need to be addressed first before he can give real numbers. He is showing the responsiveness of the turbo, hence the Part 1.
I am completely aware of that it is not supposed to be bout HP and tq. #'s. But he is referring to RPM #'s and I can't even read those. Sure I see curved lines, but without being able to read a single relevant digit besides the header, channels, and AFR, it's not really that useful even for showing "responsiveness."
Joe, just incase you were not aware of this the head is ready for a more aggressive cam profile. When I installed the prior ATP kit for Justin in conjunction with the cam, clutch, etc I installed springs and titanium retainers. Which manufacture they were I'll have to look up as my memory is weak these days. It wasn't needed, but knowing how Justin threw mods at his car I planned ahead and knew that I was going to bump the rev limit up anyway.
Call me when you want to schedule the work.
Oh and guys it's not a 40meth/60water mix...it's actually 66% meth unless Joe changed the mix recently
and yes that graph is really hard to read but it's showing peak torque and boost at about 3800RPMs on a divided 3076R(.76 a/r hotside), stock intake too
Adam Hennessy
R247Motorsports
Adam Hennessy
R247Motorsports
Thanks, that's great to know Adam. I'll definitely be giving you a call early this week to set something up!
As far as the graph goes, that's sadly as good as I could get them using my crappy software. I'll handwrite the numbers in and try to rescan asap to see if that helps. But what Adam described above is pretty much spot on - also still ~66 meth/33 water. That response is through a perrin hfc and a very quiet exhaust too!
Well even though it has some things holding it back from being at 100% of it potential, your setup sounds like something I'd love to have. Interested in seeing yor results ince you get everything sorted out and optimized.
. Can you please try to re-upload one at higher res and/or size?
