FP Red installed and running!
DynoFlash Al was his goto guy for the stock ECU stuff, don't know if he still it now though
Al is still in it fo sho! Otherwise, just read up on the ecuflash forum and scale the injectors yourself. I have FIC 1050's working perfectly on the stock ECU on pump gas, no problem. Congrats on the red!
if i were to do that would the only thing i need to do be tune the injectors. ive been reading alot about how to use ecuflash, but i didnt know if there was more to it then that.
Ya, there is more to it, but there's lots of tutorials you can use to learn what to do. Also, installing a wideband in your car helps A LOT for street tuning. There's a nifty hack to get an LC-1 wired into your stock ecu for easy logging and tuning.
I just installed the RED as well and Mellon is doing the tune. I have 680's as well but he can scale up to 1000 cc inj. and then give you an awesome tune. I would PM him as the 680's are only good for 470 whp maxed out.
