Green Turbo install tip
hey guys
i installed my green Turbo and running at .8 BAR with my OEM injectors.
is it possible to keep my 560cc injectors installed and have a propper ECU tune and run on a 1.5 BAR?
need help asap
thanks
need help asap
thanks
Yes it is possible to run the stock injectors on the GREEN but you'll be pushing them to their full duty cycle. Depending on your tune and tuner, running slightly below 1.5bar might be a wiser choice but you should be OK with the stock injectors. Consider getting bigger injectors though.
I would definately get some bigger Injectors asap.
Although the oem ones are OK, you will be pushing them to their max +..
Last thing you wanna do is starve the engine of fuel.
start saving, or see if you can find some used ones if you have to.
good luck with the Green, I love mine..
thanks guys.
to be honest i ordered my PTE 780cc like a month ago and i had to travel 400KM to have my ECU tune and i still didnt recieve my new injector so my tuner said that i should be fine with my standard injectors. he told me that i can install me 780cc when i purchase my 272 Cams and have a single tune for both upgrades in a single tune.
wish me luck huys
wish me luck huys
I have Precision 880's, which seem to be perfect for the green.
Max IDC is 65-70% or so..
Plenty of room to go up if I need.
Nice Pics mario.
Lovin the TME..
Nice Pics mario.
Lovin the TME..
