Head rattle/tap help
Old Sep 29, 2008 | 07:31 PM
turbogst311's Avatar
Hey all. I have an 06 evo se and theres a loud tapping coming from the head. My oil indiactor light comes off and on randomly but the oil level is fine. With car parked, if i tap the gas i hear the loud rattle. What could this be. Could i of bent a valve? I 2 stepped the car a few hours before but didnt hear the noise until i reached home. Its hard to explain but its a lous loud rattle/tap comin from the head. Anyone have any ideas?
Old Sep 29, 2008 | 07:33 PM
also it doesnt happen at idle, It only happens over 2000 rpms. Its definetly an internal noise.
Old Sep 29, 2008 | 09:15 PM
bso's Avatar
bso
spun bearing
Old Sep 29, 2008 | 09:20 PM
BlackonBlack2's Avatar
man i'm in the same both did cams and i think i might have bent a valve.. i'll find out tom good luck i think it might be a bearing for yours tho
Old Sep 29, 2008 | 09:21 PM
staatz's Avatar
Hmm..Wellllll..This is same wiht my car. Pretty sure it's a spun bearing also. I have not really touched the car in the past month as I don't really care to have it fixed right now. Winter is coming up and the car was going to be sitting anyways.
Old Sep 29, 2008 | 10:48 PM
ONRAILS's Avatar
spun bearing
99.999% sure. Good luck with the build
ps. I got a stg 2 stroker kit from sbr w/bs elim and new not remanned crank for like 1620 2 years ago. had the same problem.
my motor has 23k on it.
Old Sep 30, 2008 | 03:18 AM
the noise is in the head. i thought if it was a spun bearing the noise would be heard in the short block.
Old Sep 30, 2008 | 03:21 AM
the cars driveable, the loud rattles just there.
Old Sep 30, 2008 | 09:40 AM
ONRAILS's Avatar
it sounds like its from the head. But its not.
look back through my threads 2 years ago "head noise"
Old Sep 30, 2008 | 10:17 AM
C6C6CH3vo's Avatar
You will hear it on the head because bearings are changing oil pressure so the lifters will tap too. If this is the case every minute of engine operation is adding to the extent of damage.
Expect the worse first to be safe, but tap due to glogged lifters usually .happens at idle from my experience. Noise under load means the bearing to journal clearance is overcome from pressure indicating wear
Good luck, dont drive until it's figured out
Old Sep 30, 2008 | 10:19 AM
ONRAILS's Avatar
i wouldn't drive your car man. It will turn to rod knock before long if it is indeed a spun bearing..
pull your pan and check.
Old Sep 30, 2008 | 03:57 PM
Dragracer187's Avatar
I also have a loud noise from the head, it is only audible after 2000 rpm, not at idle, it is only heard when warmed up. When I cruise the noise comes, when a little more throttle is applied the noise goes away. Could this be a bearing also? I hope it is a bad lifter, I still have to bleed them and check if it goes away.
Old Sep 30, 2008 | 05:18 PM
huevosrancheros's Avatar
+1 on removing the oil pan for checking for a spun bearing.
Old Sep 30, 2008 | 05:30 PM
im bringing the car to work with me 2morrow to check it out,(alot easier on a lift)
Ill keep you all posted. Thanks for feedback.
Old Oct 11, 2008 | 10:51 AM
I still have a noise, seems to be coming from the head, you can hear it whenever you apply some throttle, slightest touch of throttle and the ticking noise comes, never heard on deceleration. I drove like 200 miles with this noise, the noise did not get worse, could it still be a bearing?? I will flush the oil next weekend to see if it is contaminated from bearing material. If you have a bad lifter, you would hear it also at idle right?? I don't have any ticking at idle. Please advise.
