Head rattle/tap help
Old Oct 11, 2008 | 02:53 PM
ONRAILS's Avatar
drag racer.. sounds like the same thing.
just pull your oil pan. I doubt you'll find anything in the oil.
Old Oct 11, 2008 | 04:27 PM
Joshs EVO's Avatar
I have this same problem, my oil light come on every now and then. It flickers and stuff. I got this loud ticking also. Speeds up and slows down when I drive. So I was also told I spun a bearing.
I knew this would happen, I am pushing 550 on the stock block so it finally happened. I bought a beater DD to drive until I have the money to do it the right way and make a beast for the streets here in Colorado.
Old Oct 11, 2008 | 04:45 PM
turbogst311's Avatar
still nothing. I took the head/oil pan off and found nothing abnormal. The pistons/rods look good. the bearings are also still in good condition. A little scoring but nothing that concerns me. I cant find where the rattle came from. When the motor was running, I found out it was cyclinder 2. As soon as i unhooked the spark from cyclinder 2 (pulled spark plug wire out) the sound went away. Im going to pull the short block out this weekend. With the head/ oil pan off, Whats the easiest way to pull the short block out. Can i leave the trans/transfer case in the car? Or do i have to pull it out with trans. Thanks for feedback guys.
Old Oct 12, 2008 | 07:09 AM
anyone?
Old Oct 12, 2008 | 05:20 PM
ONRAILS's Avatar
my stuff wasnt even scored it just had hot spots didn't even need to be turned .001
Old Oct 13, 2008 | 10:11 PM
7oey's Avatar
Same thing happened to me. Got on it and threw off the drive belt (serpintine). Thought it was my head cause drive belt connected to water pump and was making noise in the head. It's the bearings, and what you are describing happened to me...I stopped and had it towed home(thank you AAA 100 miles).
Old Oct 16, 2008 | 04:28 AM
Dragracer187's Avatar
is it possible to change bearings without taking the engine out? is there a how to for this? Or is it not advised to do this cause the bearingmaterial could be gone anywhere in the engine?? I have a light knocking noise, not sure how bad it is.
Old Oct 16, 2008 | 07:20 AM
rcheung's Avatar
Any update?
Old Dec 13, 2008 | 05:20 AM
While the motor was getting built They found that my main bearings were shot. Damaged badly. Im just glad they found a problem. Motors almost done. I should be picking it up around christmas. There also porting the head for me. Thanks for all the feedback everyone.
jbuhrman
28
May 2, 2016 12:08 PM
p1llar
Feb 7, 2013 05:02 PM
EvilDylan
18
Oct 30, 2008 04:19 PM
troe666
10
Sep 5, 2006 01:01 AM
nrcooled
Jan 21, 2006 04:45 PM
