Why is SBR stroker kit so cheap?
Old Sep 30, 2008 | 11:38 AM
rcheung's Avatar
The 2.3 stroker kit on the slowboy racing website seems to be about a thousand dollars less than his competitors.
http://www.slowboyracing.com/sbs/sbr...at=1245&page=1
Has anyone used this with success?
Old Sep 30, 2008 | 11:44 AM
Exciting News's Avatar
They use a remanufactured crank. A new one is $500 more, so that would cut into the $1000 difference right off the bat.
Old Sep 30, 2008 | 01:41 PM
Dave@TTP's Avatar
Supply and Demand....
Old Sep 30, 2008 | 02:36 PM
sabastian458's Avatar
that is only 200 more than what I got mine for. and I bought all the parts seperatly from different vendors.
Old Sep 30, 2008 | 02:38 PM
Erik@MIL.SPEC's Avatar
IIRC, they also have a machine shop on the premises, so you're not paying someone else to do the work for you.
Old Sep 30, 2008 | 02:46 PM
SBR JSO's Avatar
That kit is with a re-man crank, new would add $400. We do sell a ton of these kits so we are able to sell them pretty cheap and not be stingy with the quality of the parts in the kit. Web prices are usually a little higher than phone orders so I will PM you with a good price. Thanks for you interest.
Old Sep 30, 2008 | 02:56 PM
Jim in Tucson's Avatar
Originally Posted by SBR JSO
That kit is with a re-man crank, ...
Does this mean the rod journals are welded and re-ground?
Old Sep 30, 2008 | 03:00 PM
wreckleford's Avatar
Or cut undersize?
Old Sep 30, 2008 | 03:04 PM
SBR INC's Avatar
We typically throw away ones that need welded - however some are "cut, or ground" as far as the re-man'd crank goes yes... but we are not into welding crankshafts, we would throw those away.
You are always welcome to buy a new one... !!! (we have very limited supply of used cranks that only need polished).
MGH
Old Sep 30, 2008 | 03:12 PM
DDATuned's Avatar
Originally Posted by wreckleford
Or cut undersize?
x2
Also can you pm me a good price on the kit.
Old Oct 1, 2008 | 07:36 AM
SBR JSO's Avatar
PM Sent to DSMhater.
Old Oct 1, 2008 | 08:05 AM
MGH
Do you do chamber work on your heads?
Old Oct 1, 2008 | 09:40 AM
ExViTermini's Avatar
Cut cranks do not work out very well in these engines. If your spending the money for the performance parts I'd go ahead with the extra 400 for a new one.
Old Oct 1, 2008 | 09:59 AM
cssaddictm4's Avatar
IMO it depends on the type of power you are thinking about making, then look into the brands of parts and the power that they support.
Old Oct 1, 2008 | 01:35 PM
hokiruu's Avatar
Are the reman. crank ever Magnafluxed, or just visually inspected and measured?
