4G63T MIVEC Race Engine Build
Old Oct 9, 2008 | 07:31 AM
killthelights14's Avatar
quick noob at circuit racing question.
but why would you want to rev out to 10,000 rpm on a circuit?
Old Oct 9, 2008 | 03:54 PM
bpi's Avatar
bpi
Ok...
2.3RR - cool engine, but not in my budget, especially not with international freight costs.
Thanks for the blog link zEvo, I will check it out today.
10,000rpm... well it's all relative. 2.0L circuit engine may have a usable power band of 5,000 - 10,000rpm - a 2.3L might be usable from 3,000 - 8,000. Both have the same effective power band.
IMO, it really comes down to personal preference in the end. I like an engine that revs hard, and I like to do things differently. To that end, I have been researching 2.2L setups, as I believe they may offer an ideal compromise between revs and lower rpm torque, while also being a better design from a mechanical engineering perspective (rod ratio, piston speed etc).
It's all very fascinating and an educating experience though! I have a few months (at the earliest) before I need to make a decision on the engine, so plenty of time to get things right!
Old Oct 10, 2008 | 03:22 AM
DIDYSIS's Avatar
Bushur I am sure has the goods you are looking for. Ask Dave I love that he is so down to earth and willing to talk to you.
Old Oct 10, 2008 | 06:04 AM
Ted B's Avatar
Originally Posted by bpi
Considering this will be a circuit racing engine, would it be better to run 2.0L (stock crank), 2.2L (e.g. Cosworth 94mm crank), or 2.3L (4G94 crank) as far as outright performance goes, and if so, why?
It's really quite simple. The greater the frequency of rpm changes on a given course, the more advantageous a larger displacement engine will be.
Old Oct 10, 2008 | 08:41 AM
Precision's Avatar
Originally Posted by ZyBeR
Hey dude,
You should have a look at my blog, I think you will find some interesting reading there.
Here is a teaser
Nice man, very nice.
Old Oct 12, 2008 | 05:41 PM
bpi's Avatar
bpi
Current thinking at this stage is to build a 2.2L (94mm stroke) with increased SCR.
FYI, 2.0L (88mm stroke) at 10,000rpm has a piston speed of around 29m/s. The 2.2L (94mm) crank will achieve 9,500rpm at that same piston speed of 29m/s. While I am not saying I would rev the 2.2L to that rpm, it shows that the 2.2L has a much better piston speed when you consider that you only sacrifice 500rpm for a 200cc capacity increase.
Search is now on for a quality 2.2L crank. Any suggestions?
Old Oct 13, 2008 | 11:51 PM
aalzuhair's Avatar
I would stay at a lower piston speed .... say 25m/s max
Old Oct 14, 2008 | 10:56 PM
bpi's Avatar
bpi
Does anybody know what the length of the rods in the Cosworth 2.2L kit is? Their marketing constantly says "ideal rod ratio" but I can't find anywhere what the actual rod length is.
Old Oct 28, 2008 | 10:26 PM
bpi's Avatar
bpi
Found the length of the Cosworth rods... 150mm... hmmm, not too impressed.
I'm currently doing the maths to find out how far the wrist pin can be moved on a piston, to allow for a longer rod. I know of one working combination for increasing the rod length on a 2.0L, and am looking at what's involved to do a similar thing to achieve close(r) to a 2.2L capacity.
There are so many possible combinations, and when you look into custom rod and piston designs, it's just infinite.
I think the only thing holding me back from a 2.2L (apart from money) will be finding a crank that I am satisfied with from a structural point of view.
Thanks to you guys for all your help so far. If you think of anything else, feel free to add it in here!
Old Oct 29, 2008 | 10:51 AM
nitz's Avatar
you will find that the good 2.2 cranks are very expensive. you could go with an eagle 94mm crank if you wanted to keep costs down. other than that the other sources that do a 2.2 with long rods are marco at www.magnusmotorsports.com and mark at www.madevelopments.com. you may also want to consider running a destroked 4g64 2.2 setup, which is more economical to build. you can run a 94mm crank, 160mm rods and custom 87mm pistons. norris designs, www.norrisdesigns.com, builds motors like these and probably can supply you will the internals as a kit. short of that you can contact moses, moses@amsperformance.co.uk or moses@gscmotorsports.co.uk, who sometime stocks such a kit.
good luck.
RSMike
138
Jul 20, 2025 09:19 AM
R/TErnie
80
Jan 7, 2021 02:46 PM
Tray@Forged
EvoX 'For Sale' Engine Internals and Drivetrain
Feb 11, 2016 08:15 PM
KennyRS
76
Oct 10, 2012 07:58 AM
Mark@AMS
Automotosports - Illinois
Mar 16, 2010 03:47 PM
