Turbo install how many hours did it take you?
Old Oct 3, 2008 | 06:59 AM
mugen777's Avatar
Hey guys my red should be here in the next week or so... Just looking to see how long it took some of you guys to bolt up any stock appearing turbos aka greens, stock IX's, 20g's etc..
ill be using all new parts, hardware, gaskets...
I will probably just roll my car up on some ramps and have at it
When i bolted a 16g into my gsx a few years back seems that it was about an all day job
Thanks!
Old Oct 3, 2008 | 07:02 AM
TeStUdO's Avatar
Be sure to take out the radiator to make the job easier. It should take you 4 hours at most IF the O2 housing doesnt give you a hard time.
Old Oct 3, 2008 | 07:06 AM
MR Turco's Avatar
if you dont run into any problems probably a few hours. I have gotten the exhaust mani off in about 45min then there isn't much to do from there. if you are reusing the O2 housing it may take some more time.
Old Oct 3, 2008 | 07:08 AM
mugen777's Avatar
ive got a new o2 housing(epm), exhaust mani, turbo, gaskets, lines, and hardware
So hopefully with a hand from a buddy I can knock it out fairly quickly
Old Oct 3, 2008 | 07:12 AM
TeStUdO's Avatar
Just unbolt the oil/coolant lines first. Unbolt the exhaust manifold, down pipe, and compressor outlet and pull the whole unit out as one. That makes it alot easier since you wont have to deal with the O2 Housing.
Start putting PB blaster on the O2 sensor now to hopefully loosen it some. You will probably have to take a torch to it to get it out though.
Evo9tunerz's Avatar
It took me a couple of hours. It gets easier as you do it more often. Just make sure you spray PB blaster on the bolts and let it do its magic.
wowzers
May 2, 2016 02:03 AM
caneman22
Apr 15, 2016 08:39 PM
fishie36
Nov 11, 2013 07:50 AM
turbotsi
Lancer Engine Tech
Feb 4, 2013 06:08 PM
DeliriouS
18
Mar 13, 2010 05:51 AM
