Deciding between the 35R and 37R
Old Oct 5, 2008 | 10:08 PM
  #31
AWD Motorsports's Avatar
Originally Posted by Migsubishi
Yea but what people seem to miss is that it doesn't sacrifice anything. The Hta makes 40 more hp than the 62mm from 3200 to 6200 and after 6200 is where the 62mm wheel pulls the same 40 whp over the Hta to 8500.
For a daily, Hta35r wins, for a weekend warrior or track the 62mm wins. It all depends on what you want.
If I ever change up it will be to the new FP turbo thats about to come out if not the FS635
for me i could care less what happens at 3200 to 6200 rpm because i would rather give up spool which means brake boost or downshift, then give 40hp on top which you can get back if you never had it.. That is my turbo theory..
Old Oct 5, 2008 | 10:13 PM
  #32
Migsubishi's Avatar
I agree for a race car, or weekend warrior. Just for me the power under the curve is awesome because being daily driven that is where I spend most of my time. If all I did was race the car on the weekends or at the track I would feel the same.
Old Oct 5, 2008 | 10:39 PM
  #33
Meanmachine04's Avatar
Damnn ill have to look into that twin scroll deal! I like the way you put it haha just twin scroll and go forth and destroy haha
Old Oct 6, 2008 | 06:46 AM
  #34
Nissan2Evo's Avatar
Originally Posted by Abicus
All of you that ordered the FS635 w/ .63 hotside lets hear some results!
I'll definitely have a review up once it's back on the raod...my beast has quite an extensive Buschur mod list as well
Old Oct 6, 2008 | 07:17 AM
  #35
hokiruu's Avatar
I would not even be considering a 37R if I were looking for what it sounds like you are. Have you ever ridden in a 37R car? The only one I have ever been in was a 2.3, and it was still pretty laggy compared to a 35R IMO. Plus it had a lower redline. If you do go that big, I'd go twin scroll, or maybe a 2.3. I'd even go Twin scroll for a 35R. But I simply do not see any advantage whatsoever in the 37R over the 35R for you.
Old Oct 6, 2008 | 07:18 AM
  #36
90GSXDan's Avatar
What about the Precision mut turbo? 6282 I believe? Will probably get you the same spool as the HTA35r with almost the same power potential of the 6262.
Good luck on your turbo quest!
Dan
Old Oct 6, 2008 | 08:42 AM
  #37
No I havent ridden in a 37R umm im the only one around here with a EVO unless you drive almost 2hrs lol. My friend has one here but doesnt have that much done and im not sure what he plans on doing. Ill have to look around for the right one
Old Oct 6, 2008 | 09:14 AM
  #38
hokiruu's Avatar
Based on my aforementioned 37R experience, I don't think you could get me to run a 37R on my car if you gave it to me for free. Almost useless for anything except all-out drag IMO.
The drag, highway, and numbers people are going to disagree with me here and say "lag is overrated" etc, but...
35R is a bit laggy for anything except in a straight line, at least on a 2.0
HTA35R alleviates this a bit without compromising top end.
Twin scroll 35R is great and probably the only configuration I would ever run a 35R.
2.3 helps with the lag by 4-500rpm and gives you more low end tq., but you lose usable upper RPM with it. 2.3+ HTA is not a bad idea if you want more lower end tq and faster spool than top end out of a 35R.
What is making the impressive drag times and what is fun on the street can bevery different.
Read up, and ride up before you make a decision.
Old Oct 6, 2008 | 05:20 PM
  #39
JC evo1's Avatar
In my opinion from the various dyno charts posted on this forum the 37r is pretty much obsolete performance wise. There are so many better options available now you would be mad to run a straight 37r.
Old Oct 6, 2008 | 06:12 PM
  #40
Knguyen228's Avatar
Go 42r!!! Bwahahaha
http://www.youtube.com/watch?v=Iyl61...eature=related
old vid from ams 42r on the street.
just showing you even if it lags, its only lags on the first gear you are in, but after that, the BEAST is UNLEASHED!!!
MisUnderStood
For Sale - Wheels / Tires
13
Jul 20, 2016 04:40 PM
CammedEvo
Oct 25, 2010 06:32 PM
bertune
10
May 22, 2009 10:42 AM
4cefed
29
Dec 6, 2007 10:59 AM
WongFu
92
Jul 20, 2007 05:39 PM
