New o2 sensor and still codes????????
Old Oct 9, 2008 | 03:45 PM
brandon1304's Avatar
Put a new front o2 sensor in and within the 1st seven miles the codes p0133 p0134 popped up.... Can anyone chime in on what might the problem be?????
Old Oct 9, 2008 | 04:15 PM
bump
Old Oct 9, 2008 | 04:28 PM
rcheung's Avatar
With those codes im hoping you changed the O2 sensor in the front and not the rear. It could also be a wiring harness issue where the O2 connects to the harness.
Old Oct 9, 2008 | 04:34 PM
Yes, i replaced the front o2 , and the wiring looks intact.... anyone else????
Old Oct 9, 2008 | 05:09 PM
anyone?
Old Oct 9, 2008 | 05:16 PM
RazorLab's Avatar
Sounds like circuit is still open. Trace ground. OEM 02 sensor?
Old Oct 9, 2008 | 05:33 PM
Not OEM it is a walker from oxygensensors.com it was a OE style plug right in.
Old Oct 10, 2008 | 06:35 AM
bump
Old Oct 10, 2008 | 06:42 AM
sabastian458's Avatar
that is the same issue i ran into with that o2 sensor. I had to ge a factory 1 to fix it.
Old Oct 10, 2008 | 03:44 PM
yeah well i boxed it back up and sent it right back to get my money back. So i just ordered a new OEM one from extreme PSI and hopefully this fixes my problem.
