Vaccum at Idle on boost Gauge
Maybe I'm mistaken but if you have a hose leak on one of the smaller lines your vacuum would read lower due to the lost pressure from a leaky hose. you might want to check vacuum lines on throttle body as mine used to blow off and I would not boost above 24-25 psi. Zip tied the line and all is good.
I'm not saying this is your problem in so much as something to check out.
pretty sure I'm around 19psi vacuum at idle
I would do a boost test for sure because you can still boost with a leak its just your turbo works alot harder and you loose metered air with the leak so you loose power because your afr are off
I searched around and couldn't find anything exactly like the issue I am having. This morning I noticed that at idle the boost guage was reading a 10 vaccum, which is much more than normal. While driving it will only spike to about 10psi. The MBC is set to peak at 25psi. I am thinking it has to be a boost leak but wanted to check with the experts before I start troubleshooting? Thanks for the help.
I am having same issue, this is my first EVO, but not my first 4g63, let me know how things work out, im thinking I have some vacuum lines hooked up wrong, let me know how things work out for you. I will let you know if I find something out.
EvoIXMR
12
Nov 24, 2013 12:10 PM
TheeVOoNE
10
Apr 8, 2004 05:07 PM
