2.3 35r 880cc injectors need help confused
Old Oct 10, 2008 | 09:50 AM
Evo818's Avatar
i got a 2.3 stroker afi 35r turbo kit with cosworth 272 cams and 880 injectors... the shop that built it and base map tuned it said there is no way i can use the stock ecu to tune my car i need to get a stand alone and that i should not drive the car till i get the aem stand alone... so the car has been parked other shops have told me i can tune open source or use ecu-tek and i will have no problem with drivability where it bogs out cause of mas air flow sensor
what should i do park it till stand alone or have some other shop tune it
Old Oct 10, 2008 | 09:53 AM
4drboost's Avatar
Stock Ecu is more then capable with your setup.
Old Oct 10, 2008 | 09:57 AM
evoracingstar's Avatar
u can run stock ecu with ur setup! there are people out there running stock ecu and runings 9's lol
Old Oct 10, 2008 | 10:00 AM
2003lancerevo8's Avatar
aparently you need to take it to a different shop, there is no reason why you can't run the stock ECU on that setup. It's been done multiple, multiple times
Old Oct 10, 2008 | 10:01 AM
I guess I should follow it up with, If I had to redo my car, the aem is something I would have done.
I have driven in my car with a custom flash and a similiary built evo with a 30R and the aem and his car drove 10X smoother than mine.
I just did not want to spend the money on the AEM
Old Oct 10, 2008 | 10:09 AM
Evo818's Avatar
so i can daily drive it no problem just the aem will be smoother?
Old Oct 10, 2008 | 12:47 PM
Ev0cRaZy's Avatar
I have a stroker, 880cc Injectors and 37r w/ S2 Cams and ran stock ecu. I just switched to AEM, I can say AEM is ALOT smoother but with a good tuner your car will made mid 500's-600whp on racegas on stock ecu.
Old Oct 10, 2008 | 01:30 PM
Jason05RS's Avatar
I have an evo by me running the bushcur HTA35R kit with big cams and 880's and its an animal on stock ecu. Definitely need different tuner. My tuner will be doing my car with 1050's soon. Will it be a nice as an AEM....No, but it will work, and pass my NY inspections without re wiring my car.....
Old Oct 10, 2008 | 02:07 PM
scheides's Avatar
EvoM Moderator
Go for it, I'm running 1050's on the stock ECU. Whoever is spreading this garbage info about not being able to run bigger than 780's on the stock ECU needs to STFU.
Old Oct 10, 2008 | 02:41 PM
LT1runner's Avatar
I ran a 2.3 ltr HTA35R, 1000cc intrs,on the stock ECU, and I had no issues. The car is currently on BR's 272 cams and indy's V2 intake 1200cc injtrs, and a HTA37R. The car isn't tunned yet, but it's still running fine. Idles alittle high due to the 1200cc inj, but no issues. car drives fine off of the 1000cc tune.
Get rid of those 880s and get a set of 1000s.
Old Oct 10, 2008 | 04:11 PM
Ted B's Avatar
I am presently running 1250cc injectors, bigger cams than anything around, head ported as far as physically possible, DI intake manifold and Hypertune TB, with a large turbo, all with the factory ECU and on 93 octane. Any idiot could easily drive this car without a hitch, and I'm not even halfway finished tuning it.
Be patient, find someone who knows how to tune a factory ECU, and keep the $3000 (AEM + tuning) in your pocket.
Old Oct 11, 2008 | 08:25 PM
justboosted02's Avatar
<----- stock ecu, kelford 272s, pte 880s
